[MOAB-dev] r5485 - in MOAB/trunk: itaps/imesh src/parallel src/parallel/moab tools/mbcoupler
tautges at mcs.anl.gov
Wed Apr 18 15:49:28 CDT 2012
Author: tautges
Date: 2012-04-18 15:49:28 -0500 (Wed, 18 Apr 2012)
New Revision: 5485
Added:
MOAB/trunk/itaps/imesh/iMeshP_extensions.h
Modified:
MOAB/trunk/itaps/imesh/Makefile.am
MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp
MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
MOAB/trunk/itaps/imesh/iMesh_extensions.h
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/src/parallel/ReadParallel.cpp
MOAB/trunk/src/parallel/moab/ParallelComm.hpp
MOAB/trunk/tools/mbcoupler/Coupler.cpp
MOAB/trunk/tools/mbcoupler/Makefile.am
Log:
- move iMesh_getCommunicator to iMeshP
- add an optional file set to exchange_ghost_cells, if specified new ghosts are added to the file set
- change mbcoupler to allow solution transfer to lower order vertices of higher-order elements
Passes make check in parallel.
Modified: MOAB/trunk/itaps/imesh/Makefile.am
--- MOAB/trunk/itaps/imesh/Makefile.am 2012-04-18 18:13:07 UTC (rev 5484)
+++ MOAB/trunk/itaps/imesh/Makefile.am 2012-04-18 20:49:28 UTC (rev 5485)
@@ -1,4 +1,4 @@
-BUILT_SOURCES = iMesh_protos.h iMeshP_protos.h iMesh_extensions_protos.h
+BUILT_SOURCES = iMesh_protos.h iMeshP_protos.h iMesh_extensions_protos.h iMeshP_extensions_protos.h
MESHDIR = $(top_srcdir)/MeshFiles/unittest
@@ -33,7 +33,7 @@
if PARALLEL
libiMesh_la_SOURCES += iMeshP_MOAB.cpp
- libiMesh_la_include_HEADERS += iMeshP.h iMeshP_f.h iMeshP_protos.h
+ libiMesh_la_include_HEADERS += iMeshP.h iMeshP_extensions.h iMeshP_extensions_protos.h iMeshP_f.h iMeshP_protos.h
AM_CPPFLAGS += -I$(top_srcdir)/src/parallel -I$(top_srcdir)/src/parallel/moab
# check_PROGRAMS += partest iMeshP_unit_tests moabtest
@@ -101,3 +101,7 @@
iMeshP_protos.h: iMeshP.h ../mkprotos.sh
$(AM_V_GEN)$(srcdir)/../mkprotos.sh iMeshP MOAB $< $@ MOAB_FCDefs.h
+iMeshP_extensions_protos.h: iMeshP_extensions.h ../mkprotos.sh
+ $(AM_V_GEN)$(srcdir)/../mkprotos.sh iMeshP MOAB $< $@ MOAB_FCDefs.h
Modified: MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp
--- MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp 2012-04-18 18:13:07 UTC (rev 5484)
+++ MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp 2012-04-18 20:49:28 UTC (rev 5485)
@@ -1,4 +1,4 @@
-#include "iMeshP.h"
+#include "iMeshP_extensions.h"
#include "iMesh_MOAB.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
@@ -1887,6 +1887,55 @@
err);
+/** \brief Assign a global id space to entities
+ * Assign a global id space to entities and vertices, and optionally intermediate-dimension entities
+ * COMMUNICATION: Collective.
+void iMeshP_assignGlobalIds(
+ iMesh_Instance instance,
+ const iMeshP_PartitionHandle partition,
+ const iBase_EntitySetHandle this_set,
