[MOAB-dev] r5458 - MOAB/branches/Version4.5/itaps/imesh
tautges at mcs.anl.gov
Mon Apr 2 14:11:09 CDT 2012
Author: tautges
Date: 2012-04-02 14:11:08 -0500 (Mon, 02 Apr 2012)
New Revision: 5458
Modified:
MOAB/branches/Version4.5/itaps/imesh/iMesh_MOAB.cpp
Log:
Backporting v5457 changes to 4.5.
Modified: MOAB/branches/Version4.5/itaps/imesh/iMesh_MOAB.cpp
--- MOAB/branches/Version4.5/itaps/imesh/iMesh_MOAB.cpp 2012-04-02 19:00:36 UTC (rev 5457)
+++ MOAB/branches/Version4.5/itaps/imesh/iMesh_MOAB.cpp 2012-04-02 19:11:08 UTC (rev 5458)
@@ -1950,7 +1950,7 @@
CHKTAGTYPE(tag_handle, iBase_INTEGER);
*tag_values_allocated *= sizeof(int);
- *tag_values_size *= sizeof(int);
+ if (tag_values_size != tag_values_allocated) *tag_values_size *= sizeof(int);
iMesh_getArrData(instance, entity_handles,
entity_handles_size, tag_handle,
tag_values,
@@ -1970,7 +1970,7 @@
CHKTAGTYPE(tag_handle, iBase_DOUBLE);
*tag_values_allocated *= sizeof(double);
- *tag_values_size *= sizeof(double);
+ if (tag_values_size != tag_values_allocated) *tag_values_size *= sizeof(double);
tag_values,
@@ -1989,7 +1989,7 @@
CHKTAGTYPE(tag_handle, iBase_ENTITY_HANDLE);
*tag_value_allocated *= sizeof(iBase_EntityHandle);
- *tag_value_size *= sizeof(iBase_EntityHandle);
+ if (tag_value_size != tag_value_allocated) *tag_value_size *= sizeof(iBase_EntityHandle);
reinterpret_cast<void**>(tag_value),
@@ -2009,7 +2009,7 @@
CHKTAGTYPE(tag_handle, iBase_ENTITY_SET_HANDLE);
