[MOAB-dev] r5431 - MOAB/trunk/src/io
tautges at mcs.anl.gov
Tue Mar 20 09:20:53 CDT 2012
Author: tautges
Date: 2012-03-20 09:20:53 -0500 (Tue, 20 Mar 2012)
New Revision: 5431
Modified:
MOAB/trunk/src/io/WriteDamsel.cpp
Log:
Make container addresses different.
Modified: MOAB/trunk/src/io/WriteDamsel.cpp
--- MOAB/trunk/src/io/WriteDamsel.cpp 2012-03-15 19:44:06 UTC (rev 5430)
+++ MOAB/trunk/src/io/WriteDamsel.cpp 2012-03-20 14:20:53 UTC (rev 5431)
@@ -212,7 +212,7 @@
DAMSEL_HANDLE_COLLECTION_TYPE_VECTOR);
// make a damsel collection
- dseth = DMSLcoll_create(dmslModel, (damsel_handle_ptr)&seth, coll_type);
+ dseth = DMSLcontainer_tree_create(dmslModel, (damsel_handle_ptr)&seth, coll_type);
if (DAMSEL_CONTAINER_INVALID == dseth) CHK_MB_ERR_2(MB_FAILURE, "Bad handle returned by Damsel for meshset %lu.", seth);
// get all the entities & add
@@ -220,7 +220,7 @@
rval = mbImpl->get_entities_by_handle(seth, ents);
CHK_MB_ERR_2(rval, "get_entities_by_handle failed for set %lu.", seth);
if (!ents.empty()) {
- err = DMSLcoll_add_fast(dseth, (damsel_handle_ptr)&ents[0], ents.size());
+ err = DMSLcontainer_tree_add_fast(dseth, (damsel_handle_ptr)&ents[0], ents.size());
CHK_DMSL_ERR_2(err, "DMSLcoll_add_fast failed for meshset %lu.", seth);
@@ -388,7 +388,7 @@
xcoords_dtag = dmslXcoord = DMSLtag_define(dmslModel, (damsel_handle_ptr)&tmp_handle,
DAMSEL_DATA_TYPE_DOUBLE, "XCOORDS");
if (DAMSEL_TAG_INVALID == xcoords_dtag) rval = MB_FAILURE;
- tag_cont = DMSLhandle_create_vector(dmslModel, (damsel_handle) &tag_cont,
+ tag_cont = DMSLhandle_create_vector(dmslModel, (damsel_handle) &xcoords_dtag,
1, (damsel_handle*)&tmp_handle);
err = DMSLmodel_map_handles_inventing_file_handles(tag_cont);
CHK_DMSL_ERR(err, "Problem in DMSLmodel_map_handles_inventing_file_handles.");
@@ -401,7 +401,7 @@
"YCOORDS");
if (DAMSEL_TAG_INVALID == ycoords_dtag) rval = MB_FAILURE;
+ tag_cont = DMSLhandle_create_vector(dmslModel, (damsel_handle) &ycoords_dtag,
@@ -413,7 +413,7 @@
"ZCOORDS");
if (DAMSEL_TAG_INVALID == zcoords_dtag) rval = MB_FAILURE;
+ tag_cont = DMSLhandle_create_vector(dmslModel, (damsel_handle) &zcoords_dtag,
