[MOAB-dev] r5373 - MOAB/trunk/itaps/imesh
    tautges at mcs.anl.gov
    Thu Feb  2 14:59:27 CST 2012
Author: tautges
Date: 2012-02-02 14:59:27 -0600 (Thu, 02 Feb 2012)
New Revision: 5373
Modified:
   MOAB/trunk/itaps/imesh/iMesh_extensions.h
Log:
Clarifying ordering of ijk in local_dims and global_dims.
Modified: MOAB/trunk/itaps/imesh/iMesh_extensions.h
--- MOAB/trunk/itaps/imesh/iMesh_extensions.h	2012-02-02 20:57:24 UTC (rev 5372)
+++ MOAB/trunk/itaps/imesh/iMesh_extensions.h	2012-02-02 20:59:27 UTC (rev 5373)
@@ -270,9 +270,11 @@
         iMesh_Instance instance,
           /**< [in] iMesh instance handle */
         int *local_dims,
-          /**< [in] Min/max corners of local ijk parameters, -1 for unused dimensions */
+          /**< [in] Min/max corners of local ijk parameters, -1 for unused dimensions; specified as
+                    ilo, jlo, klo, ihi, jhi, khi. */
         int *global_dims,
-          /**< [in] Min/max corners of global ijk parameters, -1 for unused dimensions; NULL if running in serial. */
+          /**< [in] Min/max corners of global ijk parameters, -1 for unused dimensions; NULL if running in serial.
+                    Order similar to local_dims. */
         double *i_vals,
           /**< [in] Physical positions of i values, NULL if not placed in physical space. */
         double *j_vals,
