[MOAB-dev] r5359 - in MOAB/trunk: src/parallel src/parallel/moab test/parallel
nbertram at wisc.edu
Tue Jan 31 15:36:35 CST 2012
Author: bertram
Date: 2012-01-31 15:36:35 -0600 (Tue, 31 Jan 2012)
New Revision: 5359
Modified:
MOAB/trunk/src/parallel/TupleList.cpp
MOAB/trunk/src/parallel/moab/ParallelMergeMesh.hpp
MOAB/trunk/src/parallel/moab/TupleList.hpp
MOAB/trunk/test/parallel/parmerge.cpp
Log:
Used templates to get rid of duplicated code in TupleList class
Modified: MOAB/trunk/src/parallel/TupleList.cpp
--- MOAB/trunk/src/parallel/TupleList.cpp 2012-01-31 18:31:42 UTC (rev 5358)
+++ MOAB/trunk/src/parallel/TupleList.cpp 2012-01-31 21:36:35 UTC (rev 5359)
@@ -7,9 +7,6 @@
#include "moab/TupleList.hpp"
-typedef struct {uint v; uint i;} sort_data;
-typedef struct { ulong v; uint i;} sort_data_long;
namespace moab {
extern void fail(const char *fmt, ...);
@@ -414,6 +411,29 @@
n = n_in;
+ void TupleList::print(std::string name) const
+ std::cout<<"Printing Tuple " << name << "==================="<<std::endl;
+ unsigned long i=0,l=0,ul=0,r=0;
+ for(uint k=0; k<n; k++){
+ for(uint j=0; j<mi; j++){
+ std::cout<<vi[i++]<<" | ";
+ for(uint j=0; j<ml; j++){
+ std::cout<<vl[l++]<<" | ";
+ for(uint j=0; j<mul; j++){
+ std::cout<<vul[ul++]<<" | ";
+ for(uint j=0; j<mr; j++){
+ std::cout<<vr[r++]<<" | ";
+ std::cout<<std::endl;
+ std::cout<<"======================================="<<std::endl<<std::endl;
void TupleList::permute(uint *perm, void *work)
const unsigned int_size = mi*sizeof(sint),
@@ -452,18 +472,20 @@
const unsigned real_size = mr*sizeof(real);
const unsigned width = umax_2(umax_2(int_size,long_size),
umax_2(ulong_size,real_size));
- //const unsigned data_size = key>=mi ? sizeof(sort_data_long):sizeof(sort_data);
- const unsigned data_size = sizeof(sort_data_long);
+ const unsigned data_size = key>=mi?
