[MOAB-dev] Parallel iZoltan file for MOAB?
Tim Tautges
tautges at mcs.anl.gov
Wed Jan 25 09:22:24 CST 2012
As we've discussed before, there's currently no spec-approved file format for parallel loading. The current parallel
itaps tests are hardwired to load implementation-specific files. Until we have a spec-approved format, the same will
have to be done for the iZoltan test.
Also, at one point I requested an option in iZoltan to write the partitioning results to sets instead of entity-based
tags. That can be a big memory savings for MOAB, and is in some ways a more appropriate use of the data model (that's
my opinion, anyway). Until we have that, we'll have to continue to maintain and use exclusively MOAB's mbpart tool.
- tim
On 01/24/2012 06:13 PM, Mark Miller wrote:
> Yeah, I think it is in the ITAPS repo under interfaces/iMeshP/data.
> There should be a .h5m file there generated from the
> MOAB_iMeshP_unitTest.
> Mark
> On Tue, 2012-01-24 at 14:20 -0800, James Porter wrote:
>> At the ITAPS telecon last week, we discussed the weekly test results (as
>> usual). One thing that came up was the parallel iZoltan tests, which
>> we're currently failing[1]. We think the issue is that we need a file
>> which MOAB can understand. Any ideas on the file we should be using for
>> this?
>> - Jim
>> [1] https://itaps.mcs.anl.gov/resultsp.20120118/IZOLTANP_MOAB.results
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
