[MOAB-dev] r5324 - in MOAB/trunk: src/parallel tools
tautges at mcs.anl.gov
Thu Jan 19 00:52:49 CST 2012
Author: tautges
Date: 2012-01-19 00:52:45 -0600 (Thu, 19 Jan 2012)
New Revision: 5324
Modified:
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/tools/convert.cpp
Log:
Adding -M[0 | 1 | 2] option to mbconvert, rolls up all the parallel options
into one easy one (0=read, 1=resolve shared, 2=exchange ghosts. Also remove a few
unnecessary settings of MPI requests to null.
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2012-01-17 15:02:18 UTC (rev 5323)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2012-01-19 06:52:45 UTC (rev 5324)
@@ -1539,14 +1539,15 @@
(unsigned long)(2*n+1), (int)status.MPI_SOURCE );
for (size_t i = 0; i < n; ++i) {
- EntityHandle handle;
+ EntityHandle handle = 0;
rval = myPcomm->get_entityset_local_handle( procs[idx], recv_buf[idx][2*i+1], handle );
CHECK_MB(rval);
+ assert(handle);
if (!idMap.insert( handle, recv_buf[idx][2*i+2], 1 ).second)
error(MB_FAILURE); // conflicting IDs??????
- recv_req[idx] = MPI_REQUEST_NULL;
+ //recv_req[idx] = MPI_REQUEST_NULL;
assert( MPI_SUCCESS == MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status )
&& MPI_UNDEFINED == idx ); // check that we got them all
Modified: MOAB/trunk/tools/convert.cpp
--- MOAB/trunk/tools/convert.cpp 2012-01-17 15:02:18 UTC (rev 5323)
+++ MOAB/trunk/tools/convert.cpp 2012-01-19 06:52:45 UTC (rev 5324)
@@ -68,6 +68,7 @@
#ifdef USE_MPI
<< "\t-P - Append processor ID to output file name" << std::endl
<< "\t-p - Replace '%' with processor ID in input and output file name" << std::endl
+ << "\t-M[0|1|2] - Read/write in parallel, optionally also doing resolve_shared_ents (1) and exchange_ghosts (2)" << std::endl
#endif
<< "\t-- - treat all subsequent options as file names" << std::endl
<< "\t (allows file names beginning with '-')" << std::endl
@@ -170,6 +171,7 @@
bool print_times = false;
bool generate[] = { false, false, false };
bool pval;
+ bool parallel = false, resolve_shared = false, exchange_ghosts = false;
for (i = 1; i < argc; i++)
if (!argv[i][0])
@@ -177,7 +179,7 @@
if (do_flag && argv[i][0] == '-')
- if (!argv[i][1] || argv[i][2])
+ if (!argv[i][1] || (argv[i][1] != 'M' && argv[i][2]))
usage_error(argv[0]);
