[MOAB-dev] r5322 - in MOAB/trunk: itaps/imesh src/parallel src/parallel/moab
hongjun at mcs.anl.gov hongjun at mcs.anl.gov
Mon Jan 16 14:04:37 CST 2012
Author: hongjun
Date: 2012-01-16 14:04:33 -0600 (Mon, 16 Jan 2012)
New Revision: 5322
Modified:
   MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp
   MOAB/trunk/src/parallel/ParallelComm.cpp
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
o "post_irec" function is added
o it posts asynchronous receive before meshing
o used only for exchanging surface meshes in "exchange_owned_meshs"
o request lists are offered to "exchange_owned_meshs" from outside
o passes make check
Modified: MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp
--- MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp	2012-01-15 20:39:53 UTC (rev 5321)
+++ MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp	2012-01-16 20:04:33 UTC (rev 5322)
@@ -1550,8 +1550,10 @@
     exchange_ents[ind]->insert(itaps_cast<EntityHandle>(entity_handles[i]));
+  std::vector<MPI_Request> recv_ent_reqs, recv_remoteh_reqs;
   rval = pcomm->exchange_owned_meshs(exchange_procs, exchange_ents,
-                                               true);
+                                     recv_ent_reqs, recv_remoteh_reqs,
+                                     true);
   CHKERR(rval,"ParallelComm::exchange_owned_meshs failed");
   // delete exchange list
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp	2012-01-15 20:39:53 UTC (rev 5321)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp	2012-01-16 20:04:33 UTC (rev 5322)
@@ -5701,11 +5701,49 @@
   return MB_SUCCESS;
+ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& exchange_procs)
+  // set buffers
+  int n_proc = exchange_procs.size();
+  for (int i = 0; i < n_proc; i++) get_buffers(exchange_procs[i]);
+  reset_all_buffers();
+  // post ghost irecv's for entities from all communicating procs
+  // index reqs the same as buffer/sharing procs indices
+  int success;
+  ErrorCode result;
+  recvReqs.resize(2*buffProcs.size(), MPI_REQUEST_NULL);
+  recvRemotehReqs.resize(2*buffProcs.size(), MPI_REQUEST_NULL);
+  sendReqs.resize(2*buffProcs.size(), MPI_REQUEST_NULL);
+  int incoming = 0;
+  for (int i = 0; i < n_proc; i++) {
+    int ind = get_buffers(exchange_procs[i]);
+    incoming++;
+    PRINT_DEBUG_IRECV(procConfig.proc_rank(), buffProcs[ind],
+                      remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE,
+                      MB_MESG_ENTS_SIZE, incoming);
+    success = MPI_Irecv(remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE,
+                        MPI_UNSIGNED_CHAR, buffProcs[ind],
+                        MB_MESG_ENTS_SIZE, procConfig.proc_comm(),
+                        &recvReqs[2*ind]);
