[MOAB-dev] Does the ScdMeshF90 test pass for anyone in 32-bit?
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Fri Jan 13 14:14:20 CST 2012
This build is on my laptop. Maybe on mcs the issue is this one, found by Tim: https://trac.mcs.anl.gov/projects/ITAPS/wiki/HdfOnMcs Iulian ----- Original Message -----
| It works for me in serial, shared build, 32 bit, with occ or with
| cubit 12.2
| I am not sure why it would not work for the buildbot.
| I can give you my ldd output:; hdf5 is built serially, too.
| iulian at latitude:~/source/MOAB_occ/itaps/imesh$ ldd .libs/ScdMeshF90
| linux-gate.so.1 => (0x00654000)
| libiMesh.so.0 => /home/iulian/lib/serial/moab_occ/lib/libiMesh.so.0
| (0x00d46000)
| libMOAB.so.0 => /home/iulian/lib/serial/moab_occ/lib/libMOAB.so.0
| (0x00110000)
| libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00bfa000)
| libgfortran.so.3 => /usr/lib/libgfortran.so.3 (0x007e6000)
| libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0x0055a000)
| libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00e9f000)
| libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0x00655000)
| libnetcdf.so.4 => /usr/lib/libnetcdf.so.4 (0x00580000)
| libhdf5.so.6 => /home/iulian/lib/serial/hdf5/lib/libhdf5.so.6
| (0x00ebe000)
| libz.so.1 => /lib/libz.so.1 (0x00a34000)
| libcgm.so.0 => /home/iulian/lib/serial/cgm_occ/lib/libcgm.so.0
| (0x03558000)
| libTKSTL.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKSTL.so.0
| (0x00627000)
| libTKSTEP.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKSTEP.so.0
| (0x03f08000)
| libTKSTEP209.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKSTEP209.so.0 (0x008e2000)
| libTKSTEPAttr.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKSTEPAttr.so.0 (0x00a49000)
| libTKSTEPBase.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKSTEPBase.so.0 (0x1091f000)
| libTKIGES.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKIGES.so.0
| (0x12fd9000)
| libTKXSBase.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKXSBase.so.0
| (0x0b4fe000)
| libTKBinL.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKBinL.so.0
| (0x009ad000)
| libTKCAF.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKCAF.so.0
| (0x00af9000)
| libTKLCAF.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKLCAF.so.0
| (0x00d77000)
| libTKV3d.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKV3d.so.0
| (0x0ce4b000)
| libTKCDF.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKCDF.so.0
| (0x00b48000)
| libTKV2d.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKV2d.so.0
| (0x19750000)
| libTKService.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKService.so.0 (0x0e0a5000)
| libXt.so.6 => /usr/lib/libXt.so.6 (0x00cf0000)
| libX11.so.6 => /usr/lib/libX11.so.6 (0x02c01000)
| libXmu.so.6 => /usr/lib/libXmu.so.6 (0x007af000)
| libTKHLR.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKHLR.so.0
| (0x1c84b000)
| libTKOffset.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKOffset.so.0
| (0x01f8a000)
| libTKShHealing.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKShHealing.so.0 (0x0507a000)
| libTKFillet.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKFillet.so.0
| (0x1f838000)
| libTKFeat.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKFeat.so.0
| (0x01d2a000)
| libTKBool.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKBool.so.0
| (0x17ef7000)
| libTKBO.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKBO.so.0
| (0x0cb37000)
| libTKPrim.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKPrim.so.0
| (0x00ba8000)
| libTKMesh.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKMesh.so.0
| (0x1b19c000)
| libTKTopAlgo.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKTopAlgo.so.0 (0x01242000)
| libTKGeomAlgo.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKGeomAlgo.so.0 (0x05f55000)
| libTKBRep.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKBRep.so.0
| (0x14644000)
| libTKGeomBase.so.0 =>
| /home/iulian/3rdparty/lib/occ/lib/libTKGeomBase.so.0 (0x16b2f000)
| libTKG3d.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKG3d.so.0
| (0x0fd77000)
| libTKG2d.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKG2d.so.0
| (0x01456000)
| libTKMath.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKMath.so.0
| (0x0e649000)
| libTKernel.so.0 => /home/iulian/3rdparty/lib/occ/lib/libTKernel.so.0
| (0x07609000)
| libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0x007c6000)
| libTKSTL-6.3.0.so => /usr/lib/libTKSTL-6.3.0.so (0x13683000)
| libTKSTEP-6.3.0.so => /usr/lib/libTKSTEP-6.3.0.so (0x0b0a8000)
| libTKSTEP209-6.3.0.so => /usr/lib/libTKSTEP209-6.3.0.so (0x1dfa2000)
| libTKSTEPAttr-6.3.0.so => /usr/lib/libTKSTEPAttr-6.3.0.so (0x1f327000)
| libTKSTEPBase-6.3.0.so => /usr/lib/libTKSTEPBase-6.3.0.so (0x1cdd1000)
| libTKIGES-6.3.0.so => /usr/lib/libTKIGES-6.3.0.so (0x014c3000)
| libTKXSBase-6.3.0.so => /usr/lib/libTKXSBase-6.3.0.so (0x1e439000)
| libTKBinL-6.3.0.so => /usr/lib/libTKBinL-6.3.0.so (0x1fed3000)
| libTKLCAF-6.3.0.so => /usr/lib/libTKLCAF-6.3.0.so (0x1eb32000)
| libTKCDF-6.3.0.so => /usr/lib/libTKCDF-6.3.0.so (0x15d8d000)
| libTKCAF-6.3.0.so => /usr/lib/libTKCAF-6.3.0.so (0x17337000)
| libTKHLR-6.3.0.so => /usr/lib/libTKHLR-6.3.0.so (0x1213e000)
| libTKOffset-6.3.0.so => /usr/lib/libTKOffset-6.3.0.so (0x0b3de000)
| libTKShHealing-6.3.0.so => /usr/lib/libTKShHealing-6.3.0.so
| (0x17503000)
| libTKFillet-6.3.0.so => /usr/lib/libTKFillet-6.3.0.so (0x148d2000)
| libTKFeat-6.3.0.so => /usr/lib/libTKFeat-6.3.0.so (0x0d7ec000)
| libTKBool-6.3.0.so => /usr/lib/libTKBool-6.3.0.so (0x0182d000)
| libTKBO-6.3.0.so => /usr/lib/libTKBO-6.3.0.so (0x1fc70000)
| libTKPrim-6.3.0.so => /usr/lib/libTKPrim-6.3.0.so (0x1037d000)
| libTKMesh-6.3.0.so => /usr/lib/libTKMesh-6.3.0.so (0x0d392000)
| libTKTopAlgo-6.3.0.so => /usr/lib/libTKTopAlgo-6.3.0.so (0x0206f000)
| libTKGeomAlgo-6.3.0.so => /usr/lib/libTKGeomAlgo-6.3.0.so (0x1d3d5000)
| libTKBRep-6.3.0.so => /usr/lib/libTKBRep-6.3.0.so (0x01b5e000)
| libTKGeomBase-6.3.0.so => /usr/lib/libTKGeomBase-6.3.0.so (0x02276000)
| libTKG3d-6.3.0.so => /usr/lib/libTKG3d-6.3.0.so (0x1ed9e000)
| libTKG2d-6.3.0.so => /usr/lib/libTKG2d-6.3.0.so (0x19004000)
| libTKMath-6.3.0.so => /usr/lib/libTKMath-6.3.0.so (0x08ca3000)
| libTKernel-6.3.0.so => /usr/lib/libTKernel-6.3.0.so (0x10426000)
| libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0x00642000)
| /lib/ld-linux.so.2 (0x008c5000)
| libSM.so.6 => /usr/lib/libSM.so.6 (0x00646000)
| libICE.so.6 => /usr/lib/libICE.so.6 (0x0cd23000)
| libxcb.so.1 => /usr/lib/libxcb.so.1 (0x07c56000)
| libXext.so.6 => /usr/lib/libXext.so.6 (0x008ae000)
| libTKV3d-6.3.0.so => /usr/lib/libTKV3d-6.3.0.so (0x0816b000)
| libTKService-6.3.0.so => /usr/lib/libTKService-6.3.0.so (0x1effe000)
| libTKV2d-6.3.0.so => /usr/lib/libTKV2d-6.3.0.so (0x1786d000)
| libuuid.so.1 => /lib/libuuid.so.1 (0x0064f000)
| libXau.so.6 => /usr/lib/libXau.so.6 (0x007df000)
| libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x008be000)
| | I'm trying to fix the last of the broken builds on the buildbot
| | (moab-32bit), but so far, nothing seems to help. Earlier, it was
| | complaining that libhdf5.so was in the wrong format. I switched to
| | static builds, and now it complains that it can't find the iMesh
| | functions.
| | Any ideas?
| | - Jim
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120113/1e813731/attachment-0001.htm>
