[MOAB-dev] r5311 - in MOAB/trunk: itaps/igeom src src/moab test
iulian at mcs.anl.gov
Wed Jan 11 16:34:10 CST 2012
Author: iulian
Date: 2012-01-11 16:34:09 -0600 (Wed, 11 Jan 2012)
New Revision: 5311
Modified:
MOAB/trunk/itaps/igeom/FBiGeom.h
MOAB/trunk/itaps/igeom/testSmooth.cc
MOAB/trunk/itaps/igeom/testSmooth2.cc
MOAB/trunk/src/FBEngine.cpp
MOAB/trunk/src/moab/FBEngine.hpp
MOAB/trunk/test/mbground_test.cpp
Log:
correct a bug introduced by my previous commit
when a boundary mesh edge is split, we need a new method to construct the
new geometry boundary edges.
add the test that would have caught the error earlier
remove some compile warnings
Modified: MOAB/trunk/itaps/igeom/FBiGeom.h
--- MOAB/trunk/itaps/igeom/FBiGeom.h 2012-01-11 20:33:34 UTC (rev 5310)
+++ MOAB/trunk/itaps/igeom/FBiGeom.h 2012-01-11 22:34:09 UTC (rev 5311)
@@ -59,7 +59,7 @@
#include "iBase.h"
#include "FBiGeom_protos.h"
-//#include "iMesh.h"
#ifdef __cplusplus
extern "C" {
#endif
@@ -3988,7 +3988,7 @@
int *err);
#ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
#endif
#endif
Modified: MOAB/trunk/itaps/igeom/testSmooth.cc
--- MOAB/trunk/itaps/igeom/testSmooth.cc 2012-01-11 20:33:34 UTC (rev 5310)
+++ MOAB/trunk/itaps/igeom/testSmooth.cc 2012-01-11 22:34:09 UTC (rev 5311)
@@ -309,7 +309,7 @@
bool smooth_test(const std::string filename, FBiGeom_Instance geom) {
int err;
- char * opts = "SMOOTH;";
+ char opts[] = "SMOOTH;";
FBiGeom_load(geom, &filename[0], opts, &err, filename.length(), 8);
//FBiGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
CHECK( "ERROR : can not load a geometry" );
Modified: MOAB/trunk/itaps/igeom/testSmooth2.cc
--- MOAB/trunk/itaps/igeom/testSmooth2.cc 2012-01-11 20:33:34 UTC (rev 5310)
+++ MOAB/trunk/itaps/igeom/testSmooth2.cc 2012-01-11 22:34:09 UTC (rev 5311)
@@ -329,7 +329,7 @@
int err;
