[MOAB-dev] r5299 - MOAB/trunk/config
tautges at mcs.anl.gov tautges at mcs.anl.gov
Tue Jan 10 04:14:23 CST 2012
Author: tautges
Date: 2012-01-10 04:14:23 -0600 (Tue, 10 Jan 2012)
New Revision: 5299
Added:
   MOAB/trunk/config/damsel.m4
Log:
Forgot to add this one, and defaulting it to off.
Added: MOAB/trunk/config/damsel.m4
--- MOAB/trunk/config/damsel.m4	                        (rev 0)
+++ MOAB/trunk/config/damsel.m4	2012-01-10 10:14:23 UTC (rev 5299)
@@ -0,0 +1,73 @@
+# Check for Damsel library ((C++)
+# Sets HAVE_DAMSEL to 'yes' or 'no'
+# If HAVE_DAMSEL == yes, then exports:
+#   DAMSEL_CPPFLAGS
+#   DAMSEL_LDFLAGS
+#   DAMSEL_LIBS
+AC_DEFUN([FATHOM_CHECK_DAMSEL],[
+AC_MSG_CHECKING([if DAMSEL support is enabled])
+AC_ARG_WITH(damsel,
+[AC_HELP_STRING([--with-damsel=DIR], [Specify DAMSEL location])
+AC_HELP_STRING([--without-damsel], [Disable support for DAMSEL file format])],
+[DAMSEL_ARG=$withval
+DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-damsel=\"${withval}\""
+, [DAMSEL_ARG=])
+if test "x" != "x$DAMSEL_ARG" && test "xno" != "x$DAMSEL_ARG"; then
+  AC_MSG_RESULT([yes])
+else
+  AC_MSG_RESULT([no])
+fi
+ # if DAMSEL support is not disabled
+AC_MSG_CHECKING([if DAMSEL support available])
+AC_MSG_RESULT([])
+HAVE_DAMSEL=no
+if test "xno" != "x$DAMSEL_ARG"; then
+  HAVE_DAMSEL=yes
+    # if a path is specified, update LIBS and INCLUDES accordingly
+  if test "xyes" != "x$DAMSEL_ARG" && test "x" != "x$DAMSEL_ARG"; then
+    if test -d "${DAMSEL_ARG}/lib"; then
+      DAMSEL_LDFLAGS="-L${DAMSEL_ARG}/lib"
+    elif test -d "${DAMSEL_ARG}"; then
+      DAMSEL_LDFLAGS="-L${DAMSEL_ARG}"
+    else
+      AC_MSG_ERROR("$DAMSEL_ARG is not a directory.")
+    fi
+    if test -d "${DAMSEL_ARG}/include"; then
+      DAMSEL_CPPFLAGS="-I${DAMSEL_ARG}/include"
+    else
+      DAMSEL_CPPFLAGS="-I${DAMSEL_ARG}"
+    fi
+  fi
