[MOAB-dev] r5295 - in MOAB/trunk: src/parallel tools/mbcoupler
jvporter at wisc.edu
Fri Jan 6 15:54:47 CST 2012
Author: jvporter
Date: 2012-01-06 15:54:46 -0600 (Fri, 06 Jan 2012)
New Revision: 5295
Modified:
MOAB/trunk/src/parallel/errmem.h
MOAB/trunk/src/parallel/minmax.h
MOAB/trunk/tools/mbcoupler/errmem.h
MOAB/trunk/tools/mbcoupler/minmax.h
Log:
Fix warnings in parallel builds and mbcoupler
Modified: MOAB/trunk/src/parallel/errmem.h
--- MOAB/trunk/src/parallel/errmem.h 2012-01-06 19:57:29 UTC (rev 5294)
+++ MOAB/trunk/src/parallel/errmem.h 2012-01-06 21:54:46 UTC (rev 5295)
@@ -15,6 +15,12 @@
#ifdef __GNUC__
void fail(const char *fmt, ...) __attribute__ ((noreturn));
+static void buffer_init_(buffer *b, size_t size, const char *file)
+ __attribute__ ((unused));
+static void buffer_reserve_(buffer *b, size_t min, const char *file)
+static void buffer_free(buffer *b) __attribute__ ((unused));
#else
void fail(const char *fmt, ...);
#endif
Modified: MOAB/trunk/src/parallel/minmax.h
--- MOAB/trunk/src/parallel/minmax.h 2012-01-06 19:57:29 UTC (rev 5294)
+++ MOAB/trunk/src/parallel/minmax.h 2012-01-06 21:54:46 UTC (rev 5295)
@@ -11,32 +11,72 @@
Min, Max, Norm
+#ifdef __GNUC__
+#define MAYBE_UNUSED __attribute__ ((unused))
+#else
+#endif
#define DECLMINMAX(type, prefix) \
-static type prefix##min_2(type a, type b) { return b<a?b:a; } \
-static type prefix##max_2(type a, type b) { return a>b?a:b; } \
-static void prefix##minmax_2(type *min, type *max, type a, type b) \
-{ if(b<a) *min=b, *max=a; else *min=a, *max=b; } \
-static type prefix##min_3(type a, type b, type c) \
-{ return b<a?(c<b?c:b):(c<a?c:a); } \
-static type prefix##max_3(type a, type b, type c) \
-{ return a>b?(a>c?a:c):(b>c?b:c); } \
-static void prefix##minmax_3(type *min, type *max, type a, type b, type c) \
-{ if(b<a) *min=prefix##min_2(b,c), *max=prefix##max_2(a,c); \
- else *min=prefix##min_2(a,c), *max=prefix##max_2(b,c); }
+ static type prefix##min_2(type a, type b) MAYBE_UNUSED; \
+ static type prefix##min_2(type a, type b) { \
+ return b<a?b:a; \
+ static type prefix##max_2(type a, type b) MAYBE_UNUSED; \
+ static type prefix##max_2(type a, type b) { \
+ return a>b?a:b; \
