[MOAB-dev] r5249 - MOAB/trunk/tools/mbcoupler
tautges at mcs.anl.gov
Thu Dec 8 16:04:22 CST 2011
Author: tautges
Date: 2011-12-08 16:04:21 -0600 (Thu, 08 Dec 2011)
New Revision: 5249
Modified:
MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
MOAB/trunk/tools/mbcoupler/ElemUtil.hpp
Log:
Fix a bug with Tet interpolation in the coupler.
Modified: MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
--- MOAB/trunk/tools/mbcoupler/ElemUtil.cpp 2011-12-08 21:46:42 UTC (rev 5248)
+++ MOAB/trunk/tools/mbcoupler/ElemUtil.cpp 2011-12-08 22:04:21 UTC (rev 5249)
@@ -565,12 +565,12 @@
void LinearTet::set_vertices(const std::vector<CartVect>& v) {
this->Map::set_vertices(v);
- this->T = Matrix3(v[1][0]-v[0][0],v[1][0]-v[0][0],v[2][0]-v[0][0],
- v[1][1]-v[0][1],v[1][1]-v[0][1],v[2][1]-v[0][1],
- v[1][2]-v[0][2],v[1][2]-v[0][2],v[2][2]-v[0][2]);
+ this->T = Matrix3(v[1][0]-v[0][0],v[2][0]-v[0][0],v[3][0]-v[0][0],
+ v[1][1]-v[0][1],v[2][1]-v[0][1],v[3][1]-v[0][1],
+ v[1][2]-v[0][2],v[2][2]-v[0][2],v[3][2]-v[0][2]);
this->T_inverse = this->T.inverse();
this->det_T = this->T.determinant();
- this->det_T_inverse = 1.0/this->det_T;
+ this->det_T_inverse = (0.0 == this->det_T ? HUGE : 1.0/this->det_T);
}// LinearTet::set_vertices()
Modified: MOAB/trunk/tools/mbcoupler/ElemUtil.hpp
--- MOAB/trunk/tools/mbcoupler/ElemUtil.hpp 2011-12-08 21:46:42 UTC (rev 5248)
+++ MOAB/trunk/tools/mbcoupler/ElemUtil.hpp 2011-12-08 22:04:21 UTC (rev 5249)
@@ -61,7 +61,7 @@
class Map {
public:
/**\brief Construct a Map defined by the given std::vector of vertices. */
- Map(const std::vector<CartVect>& v) {this->vertex = v;};
+ Map(const std::vector<CartVect>& v) {this->vertex.resize(v.size()); this->set_vertices(v);};
/**\brief Construct a Map defined by n vertices. */
Map(const unsigned int n) {this->vertex = std::vector<CartVect>(n);};
/**\brief Evaluate the map on \xi (calculate $\vec x = F($\vec \xi)$ )*/
