[MOAB-dev] r5230 - MOAB/trunk/tools/mbzoltan
hongjun at mcs.anl.gov
Tue Nov 29 15:58:50 CST 2011
Author: hongjun
Date: 2011-11-29 15:58:50 -0600 (Tue, 29 Nov 2011)
New Revision: 5230
Modified:
MOAB/trunk/tools/mbzoltan/mbpart.cpp
Log:
o geometry surface partition option name is change from "-s" to "-f"
o commented lines are removed
Modified: MOAB/trunk/tools/mbzoltan/mbpart.cpp
--- MOAB/trunk/tools/mbzoltan/mbpart.cpp 2011-11-29 20:22:44 UTC (rev 5229)
+++ MOAB/trunk/tools/mbzoltan/mbpart.cpp 2011-11-29 21:58:50 UTC (rev 5230)
@@ -55,9 +55,8 @@
opts.addOpt<double>( "imbalance,i", "Imbalance tolerance (used in PHG/Hypergraph method)");
opts.addOpt<int>( "power,m", "Generate multiple partitions, in powers of 2, up to 2^(pow)");
opts.addOpt<void>( "reorder,R", "Reorder mesh to group entities by partition");
- //opts.addOpt<void>( "geom,g", "Specify if partition geometry.");
opts.addOpt<double>( "geom,g", "Specify if partition geometry and mesh size.");
- opts.addOpt<void>( "surf,s", "Specify if partition geometry surface.");
+ opts.addOpt<void>( "surf,f", "Specify if partition geometry surface.");
opts.addOpt<void>( "ghost,h", "Specify if partition ghost geometry body.");
opts.addOpt<int>( "vertex_w,v", "Number of weights associated with a graph vertex.");
opts.addOpt<int>( "edge_w,e", "Number of weights associated with an edge.");
@@ -68,7 +67,6 @@
opts.parseCommandLine( argc, argv );
MBZoltan *tool = NULL;
- //bool part_geom = false;
double part_geom_mesh_size = -1.0;
bool part_surf = false;
bool ghost = false;
@@ -83,14 +81,13 @@
bool print_time = opts.getOpt<void>(",T",0);
// check if partition geometry, if it is, should get mesh size for the geometry
- //part_geom = opts.numOptSet("geom") > 0;
if (opts.getOpt( "geom", &part_geom_mesh_size )) {
if (part_geom_mesh_size < 0.0) {
std::cerr << part_geom_mesh_size << ": invalid geometry partition mesh size." << std::endl;
return 1;
- //if (!part_geom) { // partition mesh
if (part_geom_mesh_size < 0.) { // partition mesh
tool = new MBZoltan (&mb, false, argc, argv);
@@ -152,7 +149,6 @@
clock_t t = clock();
const char* options = NULL;
- //if (part_geom) options = "FACET_DISTANCE_TOLERANCE=0.1";
if (part_geom_mesh_size) options = "FACET_DISTANCE_TOLERANCE=0.1";
ErrorCode rval = mb.load_file( input_file.c_str(), 0, options );
if (MB_SUCCESS != rval) {
