[MOAB-dev] Fortran interface to iMesh_CreateEntSet
Robert Jacob
jacob at mcs.anl.gov
Mon Nov 21 12:55:57 CST 2011
Correction, its only when I add a write statement for the value of ier
after the call to addEntArrToSet that it crashes. And the debugger
points me back to the createVtxArr call! The full code is below again.
Rob
program meshtry
implicit none
! declarations
#include "iMesh_f.h"
integer,parameter :: mysize=20
iBase_EntityHandle :: entarry
iMesh_Instance :: mesh
iBase_EntitySetHandle :: sethand
IBASE_HANDLE_T :: rpcoor,rpents
real*8 coor_data(3*mysize)
pointer(rpents,entarry(0:*))
pointer (rpcoor, coor_data)
integer :: nhands,sizehand,ier,i
integer :: geom_dim,settype
call iMesh_newMesh("MOAB", mesh, ier)
! try an imesh query function
call iMesh_getGeometricDimension(%VAL(mesh), geom_dim, ier)
write(0,*) "geom_dim", geom_dim,ier
! create vertices
call iMesh_createVtxArr(%VAL(mesh), %VAL(mysize),
%VAL(iBase_INTERLEAVED), &
%VAL(rpcoor),%VAL(3*mysize),rpents,nhands,sizehand,ier)
write(0,*) "handles",nhands,sizehand,ier
settype=1
call iMesh_createEntSet(%VAL(mesh), %VAL(settype), &
sethand,ier)
write(0,*) "createset",ier
call iMesh_addEntArrToSet(%VAL(mesh),%VAL(rpents),%VAL(nhands), &
%VAL(sethand),ier)
write(0,*) "add Ent Arr to Set",ier
end
On 11/21/11 12:20 PM, Robert Jacob wrote:
> Yes putting %VAL() around rpcoor fixed the problem.
> But I added the next line:
> %VAL(sethand),ier)
> To the code I sent out yesterday and that's crashing.
> Rob
> On 11/21/11 11:55 AM, Tim Tautges wrote:
>> The literal constant is fine; it's passing rpcoor by reference that's
>> the problem here, it should be passed by value.
>> I'll look at the code to see what's going on.
>> - tim
>> On 11/21/2011 08:53 AM, Paul Wilson wrote:
>>> Hi all,
>>> I'm not an expert on the calling interface, but any change it doesn't
>>> like you using the %VAL() construct on literal
>>> constant?
>>> On 11/21/2011 08:49 AM, Iulian Grindeanu wrote:
>>>> call iMesh_createEntSet(%VAL(mesh), %VAL(1), &
>>>> sethand,ier)
>>> What about:
>>> *myVariable = 1*
>>> call iMesh_createEntSet(%VAL(mesh), %VAL(*myVariable*), &
>>> sethand,ier)
>>> I'm just guessing!!!
>>> Paul
>>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
>>> Associate Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
>>> Chair, Energy Analysis& Policy Program ~http://nelson.wisc.edu/eap
