[MOAB-dev] Fortran interface to iMesh_CreateEntSet
Iulian Grindeanu
iulian at mcs.anl.gov
Mon Nov 21 08:49:42 CST 2011
I don't know much about F90 compiler; I think it is crashing when it is finishing (getting out), as it is printing for me the message after set creation.
It seems that the vertex coords (coord_data) are not initialized, although this alone should not cause the crash.
Iulian
----- Original Message -----
I'm trying to use the Fortran interface to iMesh. I want to create a
generic instance, define some vertex entities, and then put those in an
entity set. I can't figure out why the program below is giving a
SISSEGV error after I add the call to CreateEntSet. Any ideas? System
is ubuntu 10.04.3, Intel 11.1 and building off the trunk of MOAB. (If
you have an MCS account, its in ~jacob/MCTHead/examples/imesh/)
Rob
---------------------meshtry.F90------------------------
program meshtry
implicit none
! declarations
#include "iMesh_f.h"
integer,parameter :: mysize=20
iBase_EntityHandle :: entarry
iMesh_Instance :: mesh
iBase_EntitySetHandle :: sethand
IBASE_HANDLE_T :: rpcoor,rpents
real*8 coor_data(3*mysize)
pointer(rpents,entarry(0:*))
pointer (rpcoor, coor_data)
integer :: nhands,sizehand,ier,i
integer :: geom_dim
call iMesh_newMesh("MOAB", mesh, ier)
! try an imesh query function
call iMesh_getGeometricDimension(%VAL(mesh), geom_dim, ier)
write(0,*) "geom_dim", geom_dim,ier
! create vertices
call iMesh_createVtxArr(%VAL(mesh), %VAL(mysize),
%VAL(iBase_INTERLEAVED), &
rpcoor,%VAL(3*mysize),rpents,nhands,sizehand,ier)
write(0,*) "handles",nhands,sizehand,ier
call iMesh_createEntSet(%VAL(mesh), %VAL(1), &
sethand,ier)
write(0,*) "createset",ier
end
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20111121/c3f39d83/attachment.htm>
