[MOAB-dev] r5217 - MOAB/trunk/itaps/imesh
    tautges at mcs.anl.gov
    Wed Nov 16 15:54:14 CST 2011
Author: tautges
Date: 2011-11-16 15:54:13 -0600 (Wed, 16 Nov 2011)
New Revision: 5217
Removed:
   MOAB/trunk/itaps/imesh/ScdMesh.F90
Log:
Removing this test file in favor of ScdMeshF90.F90.
Deleted: MOAB/trunk/itaps/imesh/ScdMesh.F90
--- MOAB/trunk/itaps/imesh/ScdMesh.F90	2011-11-16 21:51:43 UTC (rev 5216)
+++ MOAB/trunk/itaps/imesh/ScdMesh.F90	2011-11-16 21:54:13 UTC (rev 5217)
@@ -1,50 +0,0 @@
-! MOAB structured mesh extension test
-! This test also tests fortran free-source format
-#define ERROR(rval) if (0 .ne. rval) call exit(1)
-program ScdMesh
-implicit none
-integer comm1, mysize,myproc,ier
-#include "iMesh_f.h"
-iMesh_Instance ::  mesh
-iBase_EntitySetHandle :: handle
-iBase_EntityHandle :: root_set
-integer :: local_dims(6),global_dims(6)
-integer :: geom_dim,num_regions, num_verts
-! declarations
-! create the Mesh instance
-local_dims(1)=0
-local_dims(2)=0
-local_dims(3)=-1
-local_dims(4)=64
-local_dims(5)=64
-local_dims(6)=-1
-global_dims(1)=0
-global_dims(2)=0
-global_dims(3)=-1
-global_dims(4)=64
-global_dims(5)=64
-global_dims(6)=-1
-call iMesh_newMesh('MOAB', mesh, ier); ERROR(ier);
-call iMesh_createStructuredMesh(%VAL(mesh), local_dims, global_dims, %VAL(0),%VAL(0),%VAL(0), %VAL(1), %VAL(-1), &
-  %VAL(-1), %VAL(-1), %VAL(0), handle, ier); ERROR(ier);
-call iMesh_getRootSet(%VAL(mesh), root_set, ier); ERROR(ier);
-call iMesh_getGeometricDimension(%VAL(mesh), geom_dim, ier); ERROR(ier);
-call iMesh_getNumOfType(%VAL(mesh), %VAL(root_set), %VAL(iBase_FACE), num_regions, ier); ERROR(ier);
