[MOAB-dev] r5215 - MOAB/trunk/itaps/imesh
tautges at mcs.anl.gov
Mon Nov 14 18:24:53 CST 2011
Author: tautges
Date: 2011-11-14 18:24:52 -0600 (Mon, 14 Nov 2011)
New Revision: 5215
Added:
MOAB/trunk/itaps/imesh/ScdMesh.F90
Modified:
MOAB/trunk/itaps/imesh/Makefile.am
Log:
Add test for createStructuredMesh iMesh extension function.
Modified: MOAB/trunk/itaps/imesh/Makefile.am
--- MOAB/trunk/itaps/imesh/Makefile.am 2011-11-15 00:22:59 UTC (rev 5214)
+++ MOAB/trunk/itaps/imesh/Makefile.am 2011-11-15 00:24:52 UTC (rev 5215)
@@ -11,6 +11,11 @@
# stuff for c test program
check_PROGRAMS = testc_cbind MOAB_iMesh_unit_tests MOAB_iMesh_extensions_tests
+if ENABLE_FORTRAN
+ check_PROGRAMS += ScdMesh
+endif
EXTRA_DIST = brick.vtk quad9.cub
libiMesh_la_SOURCES = \
@@ -54,6 +59,9 @@
MOAB_iMesh_extensions_tests_SOURCES = MOAB_iMesh_extensions_tests.cpp
MOAB_iMesh_extensions_tests_DEPENDENCIES = $(TESTDEPS)
+ScdMesh_SOURCES = ScdMesh.F90
+ScdMesh_DEPENDENCIES = $(TESTDEPS)
lib_LTLIBRARIES = libiMesh.la
libiMesh_la_includedir = $(includedir)
Added: MOAB/trunk/itaps/imesh/ScdMesh.F90
--- MOAB/trunk/itaps/imesh/ScdMesh.F90 (rev 0)
+++ MOAB/trunk/itaps/imesh/ScdMesh.F90 2011-11-15 00:24:52 UTC (rev 5215)
@@ -0,0 +1,50 @@
+! MOAB structured mesh extension test
+! This test also tests fortran free-source format
+#define ERROR(rval) if (0 .ne. rval) call exit(1)
+program ScdMesh
+implicit none
+integer comm1, mysize,myproc,ier
+#include "iMesh_f.h"
+iMesh_Instance :: mesh
+iBase_EntitySetHandle :: handle
+iBase_EntityHandle :: root_set
+integer :: local_dims(6),global_dims(6)
+integer :: geom_dim,num_regions, num_verts
+! declarations
