[MOAB-dev] r5213 - MOAB/trunk/itaps/imesh
tautges at mcs.anl.gov
Mon Nov 14 14:43:04 CST 2011
Author: tautges
Date: 2011-11-14 14:43:03 -0600 (Mon, 14 Nov 2011)
New Revision: 5213
Modified:
MOAB/trunk/itaps/imesh/iMesh_extensions.h
Log:
Structure the function declarations just right so they get name-mangled
fortran counterparts.
Modified: MOAB/trunk/itaps/imesh/iMesh_extensions.h
--- MOAB/trunk/itaps/imesh/iMesh_extensions.h 2011-11-14 19:59:32 UTC (rev 5212)
+++ MOAB/trunk/itaps/imesh/iMesh_extensions.h 2011-11-14 20:43:03 UTC (rev 5213)
@@ -224,7 +224,8 @@
/*inout*/ iBase_TagHandle **tag_handles,
/*inout*/ int *tag_handles_allocated,
/*out*/ int *tag_handles_size,
- /*out*/ int *err);
+ /*out*/ int *err
* \ingroup Tags
@@ -265,7 +266,7 @@
* global ids, which are used in shared vertex resolution.
- void iMesh_createStructuredMesh(
+void iMesh_createStructuredMesh(
iMesh_Instance instance,
/**< [in] iMesh instance handle */
int *local_dims,
@@ -292,7 +293,7 @@
/**< [inout] Entity set handle in which to put box and vertices/elements, NULL if not desired, *NULL if function should create one. */
int *err
/**< [out] Error flag. */
* \defgroup ScdMesh Structured Mesh
