[MOAB-dev] r5190 - MOAB/trunk/doc
sjackson at cae.wisc.edu sjackson at cae.wisc.edu
Tue Oct 11 16:25:01 CDT 2011
Author: sjackson
Date: 2011-10-11 16:25:01 -0500 (Tue, 11 Oct 2011)
New Revision: 5190
Modified:
   MOAB/trunk/doc/user.dox.in
Log:
Add DagMC.hpp to the MOAB Doxygen output
Modified: MOAB/trunk/doc/user.dox.in
--- MOAB/trunk/doc/user.dox.in	2011-10-10 23:42:13 UTC (rev 5189)
+++ MOAB/trunk/doc/user.dox.in	2011-10-11 21:25:01 UTC (rev 5190)
@@ -309,7 +309,8 @@
                          @top_srcdir@/src/MBTagConventions.hpp \
                          @top_srcdir@/src/MBCN.h \
                          @top_srcdir@/src/MBEntityType.h \
-                         @top_srcdir@/src/parallel/MBParallelConventions.h
+                         @top_srcdir@/src/parallel/MBParallelConventions.h \
+                         @top_srcdir@/tools/dagmc/DagMC.hpp
 # If the value of the INPUT tag contains directories, you can use the
 # FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
