[MOAB-dev] vertex to cell adjacencies in parallel
Hong-Jun Kim
hongjun at mcs.anl.gov
Tue Oct 11 11:01:19 CDT 2011
Hi, Lorenzo
By detouring wrong way, I think I finally found a bug in your code.
I thought the bug came from MOAB then, I have digged the wrong place.
To get owned elements, the line 226 in your code should be changed as follows (not pstatus[0] != PSTATUS_SHARED).
if (pstatus[0] == PSTATUS_SHARED && pstatus[0] != PSTATUS_NOT_OWNED && pstatus[0] != PSTATUS_GHOST)
Moreover, I think you'd better use bitwise operator to get it as follows.
if (pstatus[0] & PSTATUS_SHARED && !(pstatus[0] & PSTATUS_NOT_OWNED) && !(pstatus[0] & PSTATUS_GHOST))
Thanks.
Hong-Jun Kim
Post-doc researcher
MCS, Argonne National Laboratory
9700 S. Cass Ave. B240/R2147
Argonne, IL 60439
630-252-4791
----- Original Message -----
From: "Lorenzo Alessio Botti" <ihabiamx at yahoo.it>
To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
Sent: Friday, October 7, 2011 10:52:49 AM
Subject: Re: [MOAB-dev] vertex to cell adjacencies in parallel
Hi Hong-Jun,
I attach the code you can run it as
mpiexec -n 2 [exe_name] -P -R [path_to_one_of_the_mesh_files_here_attached]
Let me explain it a bit.
I start from a 5x5x5 hex cube with 2 partitions.
The cells on the interface form more or less a 5x5x1 25 hexes row.
(They do in the hex 27 mesh while in the hex 8 an hex is misplaced for some reason)
25 elements have a face on the interface, 25 elements share a face with owned cells,
20 elements have a face on boundary. You can take a look to the .vtk output.
Let me comment the output
iface faces size 25 ok
ghost cells size 50 shared = 25 ok, every face on iface has two neighbors one owned one not owned
Now the code searches the vertex adjacencies for the 25 owned cells, this is the output
owned entities = 25 adjacent entities not found = 45 this in wrong, the number of adjacencies not found should be 25 smaller, that is equal to number of faces on the boundary.
Thanks a lot.
Lorenzo
On Oct 7, 2011, at 4:53 PM, Hong-Jun Kim wrote:
> Could you please send me the code to replicate?
> Thanks.
> Hong-Jun Kim
> Post-doc researcher
> Argonne, IL 60439
> 630-252-4791
>> To: "Tim Tautges" <tautges at mcs.anl.gov>, MOAB-dev at mcs.anl.gov
>> Sent: Friday, October 7, 2011 9:47:52 AM
>> Thanks a lot for the reply.
>> Let me know if you need the code to replicate this issue...
>>>> For my application it would be very interesting to be able to
>>>> partition based on entity sets.
>>> If those entity sets form a covering for the entities (each of the
>>> entities included in exactly one of those sets), and those sets can
>>> be identified by a tag and optionally tag value, then you should be
>>> able to already read in parallel based on that partition (which has
>>> to already be in the file). See section 5 of the user's guide (in
>>> the doc subdir) and the description of how to read according to a
>>> material_set partition.
>> My request was a bit too cryptic...
>> I'm now reading parallel meshes generated with mbzoltan with the
>> partition tag set to PARALLEL_PARTITION.
>> It would be useful (for geometric h-multigrid, adaptivity based on
>> element agglomeration ecc...)
>> to repartition based on tagged entity sets that form a covering for
>> the entities
>> (such sets might be generated requiring a lot of partitions to the
>> partitioner)
>> instead of mesh elements.
>> A simpler trick would be to create a lot of tagged entity sets and run
>> in parallel
>> with n_processes = n_entity_set/n_entity_sets_per_process, using once
>> again the
>> entity sets as mesh elements.
>> In this context the entity set can be viewed as very general elements
>> (eg polygons).
>> In both cases the ability to get the adjacencies of entity set would
>> be also required.
>> By the way I've seen that you already have a polygonal element
>> implementation
>> but I don't know if it has been introduced with the same goal.
>> Now I'm still working on the standard element dG finite element
>> library
>> but later on it would be interesting to explore more general
>> implementations.
>> Lorenzo
>> On Oct 7, 2011, at 3:54 PM, Tim Tautges wrote:
>>> On 10/07/2011 04:05 AM, Lorenzo Alessio Botti wrote:
>>>> Hi all,
>>>> I have a question about getting adjacencies in parallel.
>>>> After having partitioned a mesh, resolved shared entities and
>>>> exchanged ghost cells I fail to
>>>> update the mesh cell adjacencies so to include ghost cells.
>>>> The face to elements adjacencies are correctly updated, that is the
>>>> faces obtained with
>>>> pcomm.get_iface_entities(1,2,faces); (I'm running on 2 processors)
>>>> have two neighbors one owned and one non owned.
>>>> However the vertex to cell adjacencies do not seem to be updated to
>>>> include ghost cells
>>>> and even after
>>>> mb.get_entities_by_dimension(0,3,entities);
>>>> mb.get_adjacencies(entities, 0, true, vertexEntities,
>>>> Interface::UNION);
>>>> entities.clear();
>>>> mb.get_adjacencies(vertexEntities, 3, true, entities,
>>>> Interface::UNION);
>>>> I'm not able to find vertex to not owned cells adjacencies.
>>>> Is get_adjacencies(...,create if missing=true,...) supposed to work
>>>> also for non owned cells?
>>>> It seems that the vertex to non owned cell adjacencies are detected
>>>> but not created.
>>> That sounds like a bug; Hong-Jun, could you look at that?
>>> MOAB's parallel model is that all locally-represented entities,
>>> which includes ghost and shared interface entities, should appear
>>> locally as a serial mesh, with all adjacencies and other API calls
>>> available.
>>>> Overall MOAB works fine in parallel and
>>>> pcomm.assign_global_ids(...) is useful.
>>>> Are you also planning to introduce some repartitioning
>>>> capabilities?
>>> Yes, this year's work plan includes migrating entities for
>>> repartitioning. In theory, the partitioning class in tools/mbzoltan
>>> should work to compute the new partition in parallel, though I think
>>> it's currently hardwired to run on one processor (on my list to get
>>> rid of that restriction).
>>> - tim
>>>> Thanks for help.
>>>> Lorenzo
>>> "You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory
>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>> phone: (608) 263-8485 1500 Engineering Dr.
>>> fax: (608) 263-4499 Madison, WI 53706
