[MOAB-dev] Question: Ghosting (SOLVED)
Tim Tautges
tautges at mcs.anl.gov
Thu Oct 6 14:34:02 CDT 2011
Sorry about the radio silence, it's a busy time in DOE land.
Also, Markus, can you tell me a little more about your application? Are there any features missing from MOAB that you
would find helpful?
Thanks.
- tim
On 10/05/2011 05:55 AM, Markus Mayr wrote:
> Hello,
> I just used the wrong entity set to query for the vertices. Using
> "local_entities" was my mistake. Using 0 in the
> moab->get_entities_by_type line solves my problem.
> Thanks!
> Best regards,
> Markus Mayr
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
