[MOAB-dev] r5182 - in MOAB/trunk/src/parallel: . moab
Rajeev Jain
jain at mcs.anl.gov
Mon Oct 3 17:11:25 CDT 2011
Hi Hong-Jun,
Is there some change needed for "unpack_set" function (below)?
ErrorCode WriteHDF5Parallel::unpack_set( EntityHandle set,
const unsigned long* buffer,
size_t buffer_size )
// use local variables for readability
assert(buffer_size >= 4);
assert(buffer[1]+buffer[2]+buffer[3] <= buffer_size);
CoreGen resolves MATERIAL_SET's using the "resolve_shared_sets" function before calling parallel save, the following error occurs and the process is terminated:
3 H5M *********** Debug Barrier 7 (@412)***********
0 H5M (1.60 s) creating meshset table
0 H5M (1.61 s) COMMUNICATING SHARED SET DATA (0 owned & 0 remote)
0 H5M Using buffer size of 128 for an expected message count of 0
[2] Assert(buffer[1]+buffer[2]+buffer[3] <= buffer_size) failed at WriteHDF5Parallel.cpp:1727
Terminated (signal 15)
Rajeev
>________________________________
>From: "hongjun at mcs.anl.gov" <hongjun at mcs.anl.gov>
>To: moab-dev at mcs.anl.gov
>Sent: Friday, September 30, 2011 6:26 PM
>Subject: [MOAB-dev] r5182 - in MOAB/trunk/src/parallel: . moab
>Author: hongjun
>Date: 2011-09-30 18:26:09 -0500 (Fri, 30 Sep 2011)
>New Revision: 5182
>Modified:
> MOAB/trunk/src/parallel/ParallelComm.cpp
> MOAB/trunk/src/parallel/moab/ParallelComm.hpp
>Log:
>o "created_iface" flag is added in "unpack_entities" function
>o it is used in "exchange_owned_mesh" and it is for recognizing with ghost mesh element and non-ghost newly created mesh element
>o it prevents to assign "PSTATUS_NOT_OWNED" and "PSTATUS_GHOST" for non-ghost newly created mesh elements
>o passes make check
>Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
>--- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-09-29 21:08:52 UTC (rev 5181)
>+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-09-30 23:26:09 UTC (rev 5182)
>@@ -960,12 +960,13 @@
> std::vector<EntityHandle> &L2hloc,
> std::vector<EntityHandle> &L2hrem,
> std::vector<unsigned int> &L2p,
>- std::vector<EntityHandle> &new_ents)
>+ std::vector<EntityHandle> &new_ents,
>+ const bool created_iface)
> unsigned char *tmp_buff = buff_ptr;
> ErrorCode result;
> result = unpack_entities(buff_ptr, store_remote_handles,
>- ind, false, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents);
>+ ind, false, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents, created_iface);
> RRA("Unpacking entities failed.");
> if (myDebug->get_verbosity() == 3) {
> myDebug->tprintf(4, "unpack_entities buffer space: %ld bytes.\n", (long int)(buff_ptr-tmp_buff));
>@@ -1585,7 +1586,8 @@
> // general algorithm:
> // - unpack # entities
>@@ -1769,7 +1771,8 @@
> // update sharing data and pstatus, adjusting order if iface
> result = update_remote_data(new_h, &ps[0], &hs[0], num_ps,
> (is_iface ? PSTATUS_INTERFACE :
>- (created_here ? (PSTATUS_GHOST | PSTATUS_NOT_OWNED) : 0)));
>+ (created_here ? (created_iface ? 0 : PSTATUS_GHOST
>+ | PSTATUS_NOT_OWNED) : 0)));
> RRA("");
> // need to send this new handle to all sharing procs
>@@ -5918,7 +5921,8 @@
> remoteOwnedBuffs[ind/2]->reset_ptr(sizeof(int));
> result = unpack_buffer(remoteOwnedBuffs[ind/2]->buff_ptr,
> store_remote_handles, buffProcs[ind/2], ind/2,
>- L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents);
>+ L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p,
>+ new_ents, true);
> if (MB_SUCCESS != result) {
> std::cout << "Failed to unpack entities. Buffer contents:" << std::endl;
> print_buffer(remoteOwnedBuffs[ind/2]->mem_ptr, MB_MESG_ENTS_SIZE, buffProcs[ind/2], false);
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20111003/ed9d8c55/attachment.htm>
