[MOAB-dev] r5183 - MOAB/trunk/src
iulian at mcs.anl.gov
Fri Sep 30 22:07:17 CDT 2011
Author: iulian
Date: 2011-09-30 22:07:17 -0500 (Fri, 30 Sep 2011)
New Revision: 5183
Modified:
MOAB/trunk/src/GeomTopoTool.cpp
Log:
another slight change to the "geometrization" of a plain surface set
if input set is not the root set, this set becomes the geo set of dimension 2
if input is the root set, create a new surface set.
In this case, also add the surface set to the output set, which would be the
model root in fuure models
Modified: MOAB/trunk/src/GeomTopoTool.cpp
--- MOAB/trunk/src/GeomTopoTool.cpp 2011-09-30 23:26:09 UTC (rev 5182)
+++ MOAB/trunk/src/GeomTopoTool.cpp 2011-10-01 03:07:17 UTC (rev 5183)
@@ -869,10 +869,13 @@
return rval;
// mb
- EntityHandle face ;
- rval = mdbImpl->create_meshset(MESHSET_SET, face);
- if (MB_SUCCESS != rval)
+ EntityHandle face = surface;
+ if (!surface)// in the case it is root set, create another set
+ rval = mdbImpl->create_meshset(MESHSET_SET, face);
+ if (MB_SUCCESS != rval)
return rval;
// set the geo tag
rval = add_geo_set(face, 2);
@@ -890,10 +893,13 @@
// how many edges do we need to create?
// depends on how many loops we have
// also, we should avoid non-manifold topology
- rval = mdbImpl->add_entities(face, surface_ents);
- return rval;
+ if (!surface) {// in this case, surface is root, so we have to add entities
+ rval = mdbImpl->add_entities(face, surface_ents);
+ return rval;
Skinner tool(mdbImpl);
rval = tool.find_skin(surface_ents, 1, edge_ents);
