[MOAB-dev] Retrieving all tags on a mesh
James Porter
jvporter at wisc.edu
Tue Sep 27 15:12:41 CDT 2011
On Mon, 2011-09-26 at 17:27 -0500, Hong-Jun Kim wrote:
> If you can use Moab interface, I think you can use "Core::tag_get_tags" function.
> In current iMesh interface, I think we need to modify the code for your purpose.
In that case, I think it would be worthwhile to add this to
iMesh_extensions. How do people feel about iMesh_getAllIfaceTags as the
name? (iMesh_getAllTags would be preferred, but it's in use).
If this ever went into the official spec, I'd probably suggest that the
names be like so:
iMesh_getAllTags: get all tags on any ent/set in the mesh
iMesh_getAllEntTags: get all tags on a given ent
iMesh_getAllEntSeTtags: get all tags on a given set
- Jim
> > From: "James Porter" <jvporter at wisc.edu>
> > To: moab-dev at mcs.anl.gov
> > Sent: Monday, September 26, 2011 5:13:59 PM
> > Subject: [MOAB-dev] Retrieving all tags on a mesh
> > Is there a way to retrieve handles for *every* tag on a mesh?
> > iMesh_getAllTags works for all tags on a specific entity (or set), but
> > I'd like a list of all the tags on any entity/set, preferably without
> > iterating over all of the elements in the mesh.
> > - Jim
