[MOAB-dev] "Global" tags on root set
Iulian Grindeanu
iulian at mcs.anl.gov
Fri Sep 16 17:51:42 CDT 2011
Hello,
I am using hdfview if the file is hdf5.
http://www.hdfgroup.org/hdf-java-html/hdfview/
I installed it on my laptop too.
Iulian
----- Original Message -----
Moabsters,
We sometimes store a single global value in a mesh file-- e.g. a value that was computed over the whole mesh during a calculation. The way we've been doing this is to create a sparse tag and store the value on the root set using that tag.
The major downside about doing this is that it's complex to look up the value of a global tag without writing code. This is the only way I know to do it with our existing command-line tools:
> mbsize -ll {meshfile} | grep {TAG_NAME}
But this is an annoying solution for large meshes, since `mbsize -ll` can take a long time to run.
Does anyone have a suggestion for a better way to look up the value of global tags? Is there a way to list tag values without verbosely printing the entire mesh? Also, do we have a visualization solution that can query tags on the root set?
~S
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110916/19dd29b3/attachment.htm>
