[MOAB-dev] r5149 - in MOAB/trunk: src test
tautges at mcs.anl.gov
Fri Sep 2 10:01:02 CDT 2011
Author: tautges
Date: 2011-09-02 10:01:02 -0500 (Fri, 02 Sep 2011)
New Revision: 5149
Modified:
MOAB/trunk/src/ScdElementData.cpp
MOAB/trunk/src/ScdElementData.hpp
MOAB/trunk/test/scdseq_test.cpp
Log:
test/scdseq_test.cpp: corrections to how some of the sequences are set up, that improved error
checking exposed.
src/ScdElementData.?pp: renaming elementParams member boxParams, to indicate that they're parameters
for the box (vertices, or vertices and elements for periodic boxes), rather than for the
elements. Also, in get_vertex(), adding an assertion that the parameter space of the box contains
the specified parameters.
Passes make check in serial and parallel.
Modified: MOAB/trunk/src/ScdElementData.cpp
--- MOAB/trunk/src/ScdElementData.cpp 2011-09-01 20:40:32 UTC (rev 5148)
+++ MOAB/trunk/src/ScdElementData.cpp 2011-09-02 15:01:02 UTC (rev 5149)
@@ -53,14 +53,14 @@
isPeriodic[0] = is_periodic_i;
isPeriodic[1] = is_periodic_j;
- elementParams[0] = HomCoord(imin, jmin, kmin);
- elementParams[1] = HomCoord(imax, jmax, kmax);
- elementParams[2] = HomCoord(1, 1, 1);
+ boxParams[0] = HomCoord(imin, jmin, kmin);
+ boxParams[1] = HomCoord(imax, jmax, kmax);
+ boxParams[2] = HomCoord(1, 1, 1);
// assign and compute parameter stuff
- dIJK[0] = elementParams[1][0] - elementParams[0][0] + 1;
- dIJK[1] = elementParams[1][1] - elementParams[0][1] + 1;
- dIJK[2] = elementParams[1][2] - elementParams[0][2] + 1;
+ dIJK[0] = boxParams[1][0] - boxParams[0][0] + 1;
+ dIJK[1] = boxParams[1][1] - boxParams[0][1] + 1;
+ dIJK[2] = boxParams[1][2] - boxParams[0][2] + 1;
dIJKm1[0] = dIJK[0] - (isPeriodic[0] ? 0 : 1);
dIJKm1[1] = dIJK[1] - (isPeriodic[1] ? 0 : 1);
dIJKm1[2] = dIJK[2] - 1;
@@ -132,8 +132,8 @@
// if minlist.size = 1 & maxlist.size = 1 & minlist[0] = esequence.min &
// maxlist[0] = esequence.max+(1,1,1)
if (minlist.size() == 1 && maxlist.size() == 1 &&
- minlist[0].minmax[0] == elementParams[0] &&
- maxlist[0].minmax[1] == elementParams[1])
+ minlist[0].minmax[0] == boxParams[0] &&
+ maxlist[0].minmax[1] == boxParams[1])
// complete
return true;
// else
Modified: MOAB/trunk/src/ScdElementData.hpp
--- MOAB/trunk/src/ScdElementData.hpp 2011-09-01 20:40:32 UTC (rev 5148)
+++ MOAB/trunk/src/ScdElementData.hpp 2011-09-02 15:01:02 UTC (rev 5149)
@@ -60,8 +60,9 @@
private:
- //! parameter min/max/stride, in homogeneous coords ijkh
- HomCoord elementParams[3];
+ //! parameter min/max/stride for vertices, in homogeneous coords ijkh; elements
+ //! are one less than max
+ HomCoord boxParams[3];
