[MOAB-dev] question about mbzoltan
Jason Kraftcheck kraftche at cae.wisc.edu
Thu Sep 1 16:11:21 CDT 2011
On 09/01/2011 04:09 PM, Iulian Grindeanu wrote:
> Thanks Jason,
> Yes, it is working fine now;
> Also, the ProgOptions bug was probably affecting other programs too.
> (I was telling Tim that -t is default now :) for mbpart )
> How did you debug it?
> What tools do you use to read the tags when they are in memory?
> Do you print or do you use gdb/ddd ?
I used gdb, but in this case valgrind probably would have also found the
ReorderTool bug.  I didn't use anything to debug ProgOptions other than
noticing that the code was in ReorderTool when it should not have been.
- jason
