[MOAB-dev] Make check failure (5143)
Xiabing Xu xbxu at mcs.anl.gov
Thu Sep 1 14:32:05 CDT 2011
On Sep 1, 2011, at 2:15 PM, Jason Kraftcheck wrote:
> On 09/01/2011 02:04 PM, Xiabing Xu wrote:
>> The reason is that gfortran compiler does not define __SIZEOF_SIZE_T__ on
>> fusion, resulting the error "Unknown compiler".
> The manual says it is supposed to define it:
> http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
> If you have a better suggestion, please share it.
> - jason
Maybe there is a reason the fusion disables these macros, I will check and see what they will say.
Xiabing
