[MOAB-dev] Make check failure (5143)
Jason Kraftcheck kraftche at cae.wisc.edu
Thu Sep 1 14:05:49 CDT 2011
On 09/01/2011 02:04 PM, Xiabing Xu wrote:
> Intel compiler works fine. It is the gfortran compiler that doesn't compile.
> Here is the code that fails the search for gfortran compiler:
> #elif defined(__SIZEOF_SIZE_T__)
> c gfortran
> #  define IMESH_HANDLE_T integer*__SIZEOF_SIZE_T__
> The reason is that gfortran compiler does not define __SIZEOF_SIZE_T__ on fusion, resulting the error "Unknown compiler".
Which version of gfortran?  Or is it actually g77?
- jason
