[MOAB-dev] question about mbzoltan
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Thu Sep  1 12:40:51 CDT 2011
On 09/01/2011 12:22 PM, Iulian Grindeanu wrote:
> Hello, I have a small file that I am partitioning in 2, with mbpart you
> can get mbpart if you configure moab  with  --enable-mbzoltan
> --with-zoltan=/home/fathom/3rdparty/Zoltan_v3.3
> --with-parmetis=/home/fathom/3rdparty/ParMETIS3_1/gcc  (at least on mcs
> network)
> So the command I am using is
> mbpart 2 MeshFiles/unittest/iGeom/shell.h5m shell_p2.h5m
> It seems to be working fine, the mesh is partitioned in 2, there are some
> tags defined in shell_p2.h5m
> But one existing variable length tag, that should have not been modified
> at all, has one wrong value.
> Do you have any idea what am I doing wrong? Or is this a bug in mbpart?
If it is a bug, then it is probably in the HDF5 writer, not in mbpart.
- jason
