[MOAB-dev] Make check failure (5143)
Rajeev Jain
jain at mcs.anl.gov
Wed Aug 31 17:08:25 CDT 2011
Is this problem on fusion?. It works for me, it seems like a complier issue. Look at my fusion config: /home/jain/moab
I had an error: "error while loading shared libraries: libimf.so" which went away by: source ifortvars_intel64.csh
Rajeev
>________________________________
>From: Xiabing Xu <xbxu at mcs.anl.gov>
>To: moab-dev at mcs.anl.gov
>Sent: Wednesday, August 31, 2011 3:28 PM
>Subject: [MOAB-dev] Make check failure (5143)
>Error messages:
>Making check in itaps
>make[2]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build/examples/itaps'
>make FindConnectF TagIterateC TagIterateF
>make[3]: Entering directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build/examples/itaps'
> PPF77 FindConnectF.o
>In file included from ../../itaps/imesh/iMesh_f.h:5,
> from FindConnectF.F:11:
>../../itaps/iBase_f.h:21: error: #error "Unknown compiler. Please define PTRSIZE."
>make[3]: *** [FindConnectF.o] Error 1
>make[3]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build/examples/itaps'
>make[2]: *** [check-am] Error 2
>make[2]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build/examples/itaps'
>make[1]: *** [check-recursive] Error 1
>make[1]: Leaving directory `/fusion/gpfs/home/xbxu/parvis/moab-trunk-build/examples'
>make: *** [check-recursive] Error 1
>My configuration:
>./configure --prefix=/homes/xbxu/parvis/moab-trunk-build/install --with-mpi=/fusion/group/climate/software/mpi2/mpich2-1.4/install --with-pnetcdf=/fusion/group/climate/software/pnetcdf/parallel-netcdf-1.2.0/install --with-netcdf=/fusion/group/climate/software/netcdf/netcdf-4.1.2-parallel/install --with-hdf5=/fusion/group/climate/software/hdf5/hdf5-1.8.6-parallel/install --with-zlib=/fusion/group/climate/software/zlib/zlib-1.2.5/install --with-szip=/fusion/group/climate/software/szip/szip-2.1/install --enable-debug CC=/fusion/group/climate/software/mpi2/mpich2-1.4/install/bin/mpicc CXX=/fusion/group/climate/software/mpi2/mpich2-1.4/install/bin/mpicxx FC=/fusion/group/climate/software/mpi2/mpich2-1.4/install/bin/mpif90 F77=/fusion/group/climate/software/mpi2/mpich2-1.4/install/bin/mpif77
>F77=gfortran
>Thanks,
>Xiabing
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110831/014977a6/attachment.htm>
