[MOAB-dev] r5143 - MOAB/trunk/doc
kraftche at cae.wisc.edu
Tue Aug 30 18:07:30 CDT 2011
Author: kraftche
Date: 2011-08-30 18:07:30 -0500 (Tue, 30 Aug 2011)
New Revision: 5143
Added:
MOAB/trunk/doc/MeshSet.dia
Modified:
MOAB/trunk/doc/Makefile.am
MOAB/trunk/doc/seq.pdf
MOAB/trunk/doc/seq.tex
Log:
fix out of date documentation on MeshSetSequence and document MeshSet class
Modified: MOAB/trunk/doc/Makefile.am
--- MOAB/trunk/doc/Makefile.am 2011-08-30 21:44:50 UTC (rev 5142)
+++ MOAB/trunk/doc/Makefile.am 2011-08-30 23:07:30 UTC (rev 5143)
@@ -4,7 +4,8 @@
seq.pdf
seq_dia = seq-uml-class.dia \
- seq-data.dia
+ seq-data.dia \
+ MeshSet.dia
EXTRA_DIST = $(doc_DATA) \
seq.tex $(seq_dia)
Added: MOAB/trunk/doc/MeshSet.dia
(Binary files differ)
Property changes on: MOAB/trunk/doc/MeshSet.dia
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: MOAB/trunk/doc/seq.pdf
Modified: MOAB/trunk/doc/seq.tex
--- MOAB/trunk/doc/seq.tex 2011-08-30 21:44:50 UTC (rev 5142)
+++ MOAB/trunk/doc/seq.tex 2011-08-30 23:07:30 UTC (rev 5143)
@@ -5,7 +5,7 @@
\title{MOAB Entity Storage}
\author{Jason Kraftcheck}
-\date{November 12, 2007}
+\date{August, 2011}
\begin{document}
\section{\texttt{EntitySequence} \& \texttt{SequenceData}}
@@ -46,7 +46,7 @@
\end{center}
\end{figure*}
-The \texttt{TypeSequenceManager} class maintains an organized set of \texttt{EntitySequence} instances and corresponding \texttt{SequenceData} instances. It is used to manage all such instances for entities of a single \texttt{MBEntityType}. \texttt{TypeSequenceManager} enforces the following four rules on its contained data:
+The \texttt{TypeSequenceManager} class maintains an organized set of \texttt{EntitySequence} instances and corresponding \texttt{SequenceData} instances. It is used to manage all such instances for entities of a single \texttt{EntityType}. \texttt{TypeSequenceManager} enforces the following four rules on its contained data:
\begin{enumerate}
\item No two \texttt{SequenceData} instances may overlap.
\item No two \texttt{EntitySequence} instances may overlap.
