[MOAB-dev] r5133 - in MOAB/trunk: src src/moab src/parallel test test/h5file test/io tools/dagmc
tautges at mcs.anl.gov
Tue Aug 30 10:47:00 CDT 2011
Author: tautges
Date: 2011-08-30 10:46:59 -0500 (Tue, 30 Aug 2011)
New Revision: 5133
Modified:
MOAB/trunk/src/Core.cpp
MOAB/trunk/src/FileOptions.cpp
MOAB/trunk/src/ScdElementData.hpp
MOAB/trunk/src/ScdInterface.cpp
MOAB/trunk/src/moab/ScdInterface.hpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/test/MBTest.cpp
MOAB/trunk/test/Makefile.am
MOAB/trunk/test/h5file/h5partial.cpp
MOAB/trunk/test/h5file/h5regression.cpp
MOAB/trunk/test/h5file/h5sets_test.cpp
MOAB/trunk/test/h5file/h5varlen.cpp
MOAB/trunk/test/io/read_nc.cpp
MOAB/trunk/test/kd_tree_test.cpp
MOAB/trunk/test/scdseq_test.cpp
MOAB/trunk/tools/dagmc/Makefile.am
MOAB/trunk/tools/dagmc/test_geom.cc
Log:
Mainly lots of bug fixes in partition computation for structured meshes.
This also adds back code that shuts down MPI if MOAB called MPI_Init. In many cases, this required
adding calls to MPI_Init/MPI_Finalize to tests that start up/shut down MOAB multiple times. This is
required because many MPI implementations (including openMPI) don't allow you to start up/shut down
MPI multiple times in the same run.
test/scdseq_test.cpp: test parallel partitioning methods more completely; also fixed bug in test
code creating structured meshes sharing faces, where 3rd coordinate of shared interface mesh was
specified wrongly; also brought this test under control of TestUtil stuff.
test/io/read_nc.cpp: startup/shutdown MPI properly if parallel version of MOAB.
src/Core.cpp: in destructor, un-comment code that calls MPI_Finalize if this instance called
MPI_Init.
src/ScdElementData.hpp: Added parametric space check/assertion
src/ScdInterface.cpp: added checks on proper parameters in get_adj_edge_or_face; also corrected
numerous bugs in partition and get_neighbor code; also added arguments to partition functions such
that they don't depend on ParallelComm, so they can be called in serial.
src/FileOptions.cpp: corrected memory leak
Passes make check in serial and parallel.
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2011-08-30 15:27:28 UTC (rev 5132)
+++ MOAB/trunk/src/Core.cpp 2011-08-30 15:46:59 UTC (rev 5133)
@@ -310,8 +310,8 @@
logfile = default_log;
MPE_Finish_log( logfile );
- //if (mpiFinalize)
- // MPI_Finalize();
+ if (mpiFinalize)
+ MPI_Finalize();
#endif
Modified: MOAB/trunk/src/FileOptions.cpp
--- MOAB/trunk/src/FileOptions.cpp 2011-08-30 15:27:28 UTC (rev 5132)
+++ MOAB/trunk/src/FileOptions.cpp 2011-08-30 15:46:59 UTC (rev 5133)
@@ -274,6 +274,7 @@
for (char* i = strtok( tmp_str, separator ); i; i = strtok( 0, separator ))
if (!strempty(i)) // skip empty strings
values.push_back( std::string(i));
+ free(tmp_str);
return MB_SUCCESS;
Modified: MOAB/trunk/src/ScdElementData.hpp
--- MOAB/trunk/src/ScdElementData.hpp 2011-08-30 15:27:28 UTC (rev 5132)
+++ MOAB/trunk/src/ScdElementData.hpp 2011-08-30 15:46:59 UTC (rev 5133)
@@ -135,6 +135,9 @@
//! test whether this sequence contains these parameters
inline bool contains(const HomCoord &coords) const;
+ //! test whether *vertex parameterization* in this sequence contains these parameters
+ inline bool contains_vertex(const HomCoord &coords) const;
//! get connectivity of an entity given entity's parameters
inline ErrorCode get_params_connectivity(const int i, const int j, const int k,
std::vector<EntityHandle>& connectivity) const;
@@ -225,6 +228,17 @@
(dIJKm1[2] && temp.k() >= elementParams[0].k() && temp.k() < elementParams[0].k()+dIJKm1[2])));
+inline bool ScdElementData::contains_vertex(const HomCoord &temp) const
+ // upper bound is < instead of <= because element params max is one less
+ // than vertex params max, except in case of 2d or 1d sequence
