[MOAB-dev] r5121 - in MOAB/trunk: . doc
Iulian Grindeanu
iulian at mcs.anl.gov
Mon Aug 29 08:40:47 CDT 2011
Hello,
It seems that some *.eps files are missing, with class diagrams
I have another error on 32 bit compiler; it seems that my compiler does not permit some casts from unsigned long int * to int *
It compiles if I force the cast, but I am not sure if it is correct
--- src/parallel/WriteHDF5Parallel.cpp (revision 5128)
+++ src/parallel/WriteHDF5Parallel.cpp (working copy)
@@ -1658,7 +1658,7 @@
unsigned long* array = reinterpret_cast<unsigned long*>(&tmp[0]);
std::copy( tmp.begin(), tmp.end(), array );
- contents = &tmp[0];
+ contents = (long int *)&tmp[0];
----- Original Message -----
> Is there anything in particular we need for this to work? It seems to
> be the cause of the Buildbot failures this weekend.
> - Jim
> On 08/26/11, kraftche at cae.wisc.edu wrote:
> > Author: kraftche
> > Date: 2011-08-26 08:31:35 -0500 (Fri, 26 Aug 2011)
> > New Revision: 5121
> > Added:
> > MOAB/trunk/doc/config.tex.in
> > Modified:
> > MOAB/trunk/configure.ac
> > MOAB/trunk/doc/Makefile.am
> > MOAB/trunk/doc/seq.tex
> > Log:
> > Add rudimentary Makefile support for latex documents.
> > This is fairly basic in that it does not include configure support
> > for
> > detecting the necessary tools (latex, dia, dvipdf, etc.) or the
> > logic
> > for handling the case where said tools are not available. So this
> > change
> > is for developer convenience only. Continue to check in generated
> > PDFs
> > so that automake doesn't try to re-build them for users.
> > config.tex(.in) (copied from Mesquite source) contains the magic for
> > doing latex in a separate build directory.
> > Modified: MOAB/trunk/configure.ac
> > --- MOAB/trunk/configure.ac 2011-08-26 13:02:21 UTC (rev 5120)
> > +++ MOAB/trunk/configure.ac 2011-08-26 13:31:35 UTC (rev 5121)
> > @@ -1145,6 +1145,7 @@
> > tools/vtkMOABReader/CMakeLists.txt
> > doc/Makefile
> > doc/user.dox
> > + doc/config.tex
> > examples/Makefile
> > examples/examples.make
> > examples/simple/makefile
> > Modified: MOAB/trunk/doc/Makefile.am
> > --- MOAB/trunk/doc/Makefile.am 2011-08-26 13:02:21 UTC (rev 5120)
> > +++ MOAB/trunk/doc/Makefile.am 2011-08-26 13:31:35 UTC (rev 5121)
> > @@ -2,7 +2,28 @@
> > doc_DATA = MOAB-UG.doc \
> > MOAB-performance.doc \
> > seq.pdf
> > +seq_dia = seq-uml-class.dia \
> > + seq-data.dia
> > -EXTRA_DIST = $(doc_DATA) seq.tex
> > +EXTRA_DIST = $(doc_DATA) \
> > + seq.tex $(seq_dia)
> > +SUFFIXES = .dia .eps .dvi .pdf .ps .tex
> > +.dia.eps:
> > + dia -e $@ -t eps $<
> > +.dvi.pdf:
> > + dvipdf $< $@
> > +.dvi.ps:
> > + dvips $< $@
> > +.tex.dvi:
> > + latex $<
> > + latex $<
> > + latex $<
> > +seq.dvi: seq.tex $(seq_dia)
> > +MOSTLYCLEANFILES = *.aux *.bbl *.blg *.lof *.log *.log *.toc
> > Added: MOAB/trunk/doc/config.tex.in
> > --- MOAB/trunk/doc/config.tex.in (rev 0)
