[MOAB-dev] r5128 - MOAB/trunk/src/parallel
tautges at mcs.anl.gov
Fri Aug 26 14:48:23 CDT 2011
Author: tautges
Date: 2011-08-26 14:48:23 -0500 (Fri, 26 Aug 2011)
New Revision: 5128
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
A bit of optimization to tagging shared vertices.
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-08-26 19:27:15 UTC (rev 5127)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-08-26 19:48:23 UTC (rev 5128)
@@ -4220,8 +4220,9 @@
RRA("Trouble getting shared proc tags in tag_shared_verts.");
unsigned int j = 0, i = 0;
- std::vector<int> sharing_procs, sharing_procs2;
- std::vector<EntityHandle> sharing_handles, sharing_handles2;
+ std::vector<int> sharing_procs, sharing_procs2, tag_procs;
+ std::vector<EntityHandle> sharing_handles, sharing_handles2, tag_lhandles, tag_rhandles;
+ std::vector<unsigned char> pstatus;
//Were on tuple j/2
if (i_extra) i += i_extra;
@@ -4248,22 +4249,22 @@
// add current proc/handle to list
sharing_procs.push_back(procConfig.proc_rank());
sharing_handles.push_back(this_ent);
- // sort sharing_procs and sharing_handles such that
- // sharing_procs is in ascending order. Use temporary
- // lists and binary search to re-order sharing_handles.
- sharing_procs2 = sharing_procs;
- std::sort( sharing_procs2.begin(), sharing_procs2.end() );
- sharing_handles2.resize( sharing_handles.size() );
- for (size_t k = 0; k < sharing_handles.size(); ++k) {
- size_t idx = std::lower_bound( sharing_procs2.begin(),
- sharing_procs2.end(),
- sharing_procs[k] ) - sharing_procs2.begin();
- sharing_handles2[idx] = sharing_handles[k];
+ // sort sharing_procs and sharing_handles such that
+ // sharing_procs is in ascending order. Use temporary
+ // lists and binary search to re-order sharing_handles.
+ sharing_procs2 = sharing_procs;
+ std::sort( sharing_procs2.begin(), sharing_procs2.end() );
+ sharing_handles2.resize( sharing_handles.size() );
+ for (size_t k = 0; k < sharing_handles.size(); ++k) {
+ size_t idx = std::lower_bound( sharing_procs2.begin(),
+ sharing_procs2.end(),
+ sharing_procs[k] ) - sharing_procs2.begin();
+ sharing_handles2[idx] = sharing_handles[k];
+ sharing_procs.swap( sharing_procs2 );
+ sharing_handles.swap( sharing_handles2 );
- sharing_procs.swap( sharing_procs2 );
- sharing_handles.swap( sharing_handles2 );
