[MOAB-dev] r5124 - in MOAB/trunk/itaps: . imesh
kraftche at cae.wisc.edu
Fri Aug 26 12:56:28 CDT 2011
Author: kraftche
Date: 2011-08-26 12:56:28 -0500 (Fri, 26 Aug 2011)
New Revision: 5124
Modified:
MOAB/trunk/itaps/iBase_f.h
MOAB/trunk/itaps/imesh/iMesh_f.h
Log:
More versatile solution for 64-bit Fortran
- work in progress
- works for gfortran (and probably intel fortran)
Modified: MOAB/trunk/itaps/iBase_f.h
--- MOAB/trunk/itaps/iBase_f.h 2011-08-26 16:48:15 UTC (rev 5123)
+++ MOAB/trunk/itaps/iBase_f.h 2011-08-26 17:56:28 UTC (rev 5124)
@@ -1,10 +1,27 @@
#ifndef IBASE_F_H
#define IBASE_F_H
-#define iBase_EntityHandle integer
-#define iBase_EntitySetHandle integer
-#define iBase_TagHandle integer
+#ifdef __GFORTRAN__
+# define IMESH_HANDLE_T integer*__SIZEOF_SIZE_T__
+#elif defined(__INTEL_COMPILER)
+# ifdef __X86_64
+# define IMESH_HANDLE_T integer*8
+# else
+# define IMESH_HANDLE_T integer*4
+# endif
+#elif defined(__XLCPP__)
+% This doesn't work. I cannot find a pre-defined macro to identify IBM XL Fortran
+ USE, INTRINSIC :: ISO_C_BINDING
+# define IMESH_HANDLE_T C_PTR
+#else
+% Appliction must define PTRSIZE for unrecognized compilers
+# define IMESH_HANDLE_T INTEGER*PTRSIZE
+#endif
+#define iBase_EntityHandle IMESH_HANDLE_T
+#define iBase_EntitySetHandle IMESH_HANDLE_T
+#define iBase_TagHandle IMESH_HANDLE_T
#endif
integer iBase_VERTEX
Modified: MOAB/trunk/itaps/imesh/iMesh_f.h
--- MOAB/trunk/itaps/imesh/iMesh_f.h 2011-08-26 16:48:15 UTC (rev 5123)
+++ MOAB/trunk/itaps/imesh/iMesh_f.h 2011-08-26 17:56:28 UTC (rev 5124)
@@ -1,14 +1,12 @@
#ifndef IMESH_F_H
#define IMESH_F_H
-#define iMesh_Instance integer*PTRSIZE
-#define iBase_EntityIterator integer*PTRSIZE
-#define iBase_EntityArrIterator integer*PTRSIZE
-#endif
#include "iBase_f.h"
