[MOAB-dev] r5121 - in MOAB/trunk: . doc
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Fri Aug 26 08:31:36 CDT 2011
Author: kraftche
Date: 2011-08-26 08:31:35 -0500 (Fri, 26 Aug 2011)
New Revision: 5121
Added:
   MOAB/trunk/doc/config.tex.in
Modified:
   MOAB/trunk/configure.ac
   MOAB/trunk/doc/Makefile.am
   MOAB/trunk/doc/seq.tex
Log:
Add rudimentary Makefile support for latex documents.
This is fairly basic in that it does not include configure support for
detecting the necessary tools (latex, dia, dvipdf, etc.) or the logic
for handling the case where said tools are not available. So this change
is for developer convenience only.  Continue to check in generated PDFs
so that automake doesn't try to re-build them for users.
config.tex(.in) (copied from Mesquite source) contains the magic for
doing latex in a separate build directory.
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2011-08-26 13:02:21 UTC (rev 5120)
+++ MOAB/trunk/configure.ac	2011-08-26 13:31:35 UTC (rev 5121)
@@ -1145,6 +1145,7 @@
 		 tools/vtkMOABReader/CMakeLists.txt
                  doc/Makefile
                  doc/user.dox
+                 doc/config.tex
                  examples/Makefile
                  examples/examples.make
                  examples/simple/makefile
Modified: MOAB/trunk/doc/Makefile.am
--- MOAB/trunk/doc/Makefile.am	2011-08-26 13:02:21 UTC (rev 5120)
+++ MOAB/trunk/doc/Makefile.am	2011-08-26 13:31:35 UTC (rev 5121)
@@ -2,7 +2,28 @@
 doc_DATA = MOAB-UG.doc \
            MOAB-performance.doc \
            seq.pdf
+seq_dia = seq-uml-class.dia \
+          seq-data.dia
-EXTRA_DIST  = $(doc_DATA) seq.tex
+EXTRA_DIST  = $(doc_DATA) \
+	      seq.tex $(seq_dia)
+SUFFIXES = .dia .eps .dvi .pdf .ps .tex
+.dia.eps:
+	dia -e $@ -t eps $<
+.dvi.pdf:
+	dvipdf $< $@
+.dvi.ps:
+	dvips $< $@
+.tex.dvi:
+	latex $<
+	latex $<
+	latex $<
+seq.dvi: seq.tex $(seq_dia)
+MOSTLYCLEANFILES = *.aux *.bbl *.blg *.lof *.log *.log *.toc
Added: MOAB/trunk/doc/config.tex.in
--- MOAB/trunk/doc/config.tex.in	                        (rev 0)
