[MOAB-dev] r5119 - MOAB/trunk/doc
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Aug 25 23:07:02 CDT 2011
Author: kraftche
Date: 2011-08-25 23:07:02 -0500 (Thu, 25 Aug 2011)
New Revision: 5119
Added:
   MOAB/trunk/doc/seq-data.dia
   MOAB/trunk/doc/seq-uml-class.dia
Modified:
   MOAB/trunk/doc/seq.pdf
   MOAB/trunk/doc/seq.tex
Log:
add some figures to document about sequence data
Added: MOAB/trunk/doc/seq-data.dia
(Binary files differ)
Property changes on: MOAB/trunk/doc/seq-data.dia
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: MOAB/trunk/doc/seq-uml-class.dia
Property changes on: MOAB/trunk/doc/seq-uml-class.dia
Modified: MOAB/trunk/doc/seq.pdf
Modified: MOAB/trunk/doc/seq.tex
--- MOAB/trunk/doc/seq.tex	2011-08-25 20:04:01 UTC (rev 5118)
+++ MOAB/trunk/doc/seq.tex	2011-08-26 04:07:02 UTC (rev 5119)
@@ -8,6 +8,13 @@
 \begin{document}
 \section{\texttt{EntitySequence} \& \texttt{SequenceData}}
+\begin{figure*}[htbp]
+\begin{center}
+\includegraphics[width=6in]{seq-data.eps}
+\caption{EntitySequences For One SequenceData}
+\end{center}
+\end{figure*}
 The \texttt{SequenceData} class manages as set of arrays of per-entity values.  Each \texttt{SequenceData} has a start and end handle denoting the block of entities for which the arrays contain data.  The arrays managed by a \texttt{SequenceData} instance are divided into three groups:
 \begin{itemize}
 \item Type-specific data (connectivity, coordinates, etc.): zero or more arrays.
@@ -29,6 +36,14 @@
 \section{\texttt{TypeSequenceManager} \& \texttt{SequenceManager}}
+\begin{center}
+\includegraphics[width=6in]{seq-uml-class.eps}
+\caption{SequenceManager and Related Classes}
