[MOAB-dev] r5112 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Wed Aug 24 17:27:24 CDT 2011
Author: kraftche
Date: 2011-08-24 17:27:20 -0500 (Wed, 24 Aug 2011)
New Revision: 5112
Modified:
MOAB/trunk/src/parallel/ReadParallel.cpp
MOAB/trunk/src/parallel/ReadParallel.hpp
Log:
resolve shared sets if resolving shared entities during parallel read
Modified: MOAB/trunk/src/parallel/ReadParallel.cpp
--- MOAB/trunk/src/parallel/ReadParallel.cpp 2011-08-24 22:26:38 UTC (rev 5111)
+++ MOAB/trunk/src/parallel/ReadParallel.cpp 2011-08-24 22:27:20 UTC (rev 5112)
@@ -32,6 +32,7 @@
"PARALLEL GET_FILESET_ENTS",
"PARALLEL RESOLVE_SHARED_ENTS",
"PARALLEL EXCHANGE_GHOSTS",
+ "PARALLEL RESOLVE_SHARED_SETS",
"PARALLEL PRINT_PARALLEL"
@@ -223,6 +224,8 @@
if (-1 != ghost_dim) pa_vec.push_back(PA_EXCHANGE_GHOSTS);
+ if (-2 != resolve_dim) pa_vec.push_back(PA_RESOLVE_SHARED_SETS);
if (print_parallel) pa_vec.push_back(PA_PRINT_PARALLEL);
result = load_file(file_names, num_files, file_set, parallel_mode,
@@ -483,6 +486,16 @@
break;
+ case PA_RESOLVE_SHARED_SETS:
+ myDebug.tprint(1,"Resolving shared sets.\n");
+ if (myPcomm->size() == 1)
+ tmp_result = MB_SUCCESS;
+ else
+ tmp_result = myPcomm->resolve_shared_sets(file_set, use_id_tag ? file_id_tag : 0);
+ break;
case PA_PRINT_PARALLEL:
myDebug.tprint(1,"Printing parallel information.\n");
@@ -704,6 +717,8 @@
result = mbImpl->remove_entities(*rit, deletable_ents);
RR("Failure removing deletable entities.");
+ result = mbImpl->remove_entities( file_set, deletable_ents );
+ RR("Failure removing deletable entities.");
myDebug.tprint( 2, "Deleting deletable entities.\n" );
Modified: MOAB/trunk/src/parallel/ReadParallel.hpp
--- MOAB/trunk/src/parallel/ReadParallel.hpp 2011-08-24 22:26:38 UTC (rev 5111)
