[MOAB-dev] r5107 - MOAB/trunk/test/parallel
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Sun Aug 21 16:34:37 CDT 2011
Author: kraftche
Date: 2011-08-21 16:34:36 -0500 (Sun, 21 Aug 2011)
New Revision: 5107
Modified:
   MOAB/trunk/test/parallel/parallel_hdf5_test.cc
Log:
fix minor bug in parallel_hdf5_test
Modified: MOAB/trunk/test/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/test/parallel/parallel_hdf5_test.cc	2011-08-18 15:12:23 UTC (rev 5106)
+++ MOAB/trunk/test/parallel/parallel_hdf5_test.cc	2011-08-21 21:34:36 UTC (rev 5107)
@@ -373,7 +373,7 @@
   std::string str;
   if (WriteDebugLevel) {
     std::ostringstream s;
-    s << opt << ";DEBUG_IO=" << ReadDebugLevel;
+    s << opt << ";DEBUG_IO=" << WriteDebugLevel;
     str = s.str();
     opt = str.c_str();
@@ -666,7 +666,7 @@
   std::string str;
     str = s.str();
     opt = str.c_str();
