[MOAB-dev] r5078 - MOAB/trunk/test
iulian at mcs.anl.gov
Wed Aug 3 11:30:19 CDT 2011
Author: iulian
Date: 2011-08-03 11:30:19 -0500 (Wed, 03 Aug 2011)
New Revision: 5078
Modified:
MOAB/trunk/test/gttool_test.cpp
Log:
add option to only add geometry sets to a surface mesh file.
Modified: MOAB/trunk/test/gttool_test.cpp
--- MOAB/trunk/test/gttool_test.cpp 2011-08-01 17:39:40 UTC (rev 5077)
+++ MOAB/trunk/test/gttool_test.cpp 2011-08-03 16:30:19 UTC (rev 5078)
@@ -75,6 +75,7 @@
remove_output_file = true;
bool only_check = false;
+ bool only_geometrize = false;
if (argc == 1) {
@@ -90,7 +91,14 @@
ofile3 = argv[1];// check model only from file
only_check = true;
remove_output_file = false; // this is input now, do not delete it
- } else {
+ } else if (argc == 3) {
+ filename = argv[1];
+ ofile = argv[2];
+ only_geometrize = true;
+ remove_output_file = false;
+ else
std::cerr << "Usage: " << argv[0] << " [surface_mesh] [mbgeo_file] [shellfile] [copyshellfile] " << std::endl;
return 1;
@@ -113,13 +121,15 @@
// FBEngine * pFacet = new FBEngine(mb, NULL, true);// smooth facetting, no OBB tree passed
std::cout << "geometrize test: ";
ErrorCode rval = geometrize_test( mb, 0); // just pass the root set
handle_error_code(rval, number_tests_failed, number_tests_successful);
std::cout << "\n";
+ if (only_geometrize)
+ return number_tests_failed;
std::cout << "create shell test: ";
rval = create_shell_test( mb);
