[MOAB-dev] r5074 - in MOAB/trunk: itaps/imesh src/parallel src/parallel/moab
hongjun at mcs.anl.gov
Sat Jul 30 10:44:04 CDT 2011
Author: hongjun
Date: 2011-07-30 10:44:04 -0500 (Sat, 30 Jul 2011)
New Revision: 5074
Modified:
MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp
MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
o "iMeshP::iMeshP_exchEntArrToPartsAll" is implemented
o Exchanges entities to assigned parts
o command_code and update_ghost options are not supported yet but will be
o test code is added in MOAB_iMeshP_unit_tests.cpp
o Passes make check
Modified: MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp
--- MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp 2011-07-29 20:08:15 UTC (rev 5073)
+++ MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp 2011-07-30 15:44:04 UTC (rev 5074)
@@ -212,6 +212,7 @@
int test_push_tag_data_iface( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
int test_push_tag_data_ghost( iMesh_Instance, iMeshP_PartitionHandle prtn, const PartMap& );
+int test_exchange_ents( iMesh_Instance imesh, iMeshP_PartitionHandle prtn, const PartMap& map );
Helper Funcions
@@ -463,6 +464,7 @@
num_errors += RUN_TEST( test_push_tag_data_iface );
num_errors += RUN_TEST( test_push_tag_data_ghost );
num_errors += RUN_TEST( test_create_ghost_ents );
+ num_errors += RUN_TEST( test_exchange_ents );
// wait until all procs are done before writing summary data
std::cout.flush();
@@ -2529,6 +2531,63 @@
return iBase_SUCCESS;
+/**\brief Test exchange entities
+ * Test:
+ * - iMeshP_exchEntArrToPartsAll
+ int ierr, rank, size;
+ int num_err = 0;
+ iMeshP_RequestHandle request;
+ MPI_Comm_rank( MPI_COMM_WORLD, &rank );
+ MPI_Comm_size( MPI_COMM_WORLD, &size );
+ std::vector<iBase_EntityHandle> all_elems;
+ std::vector<iMeshP_Part> all_ids;
+ std::vector<iBase_EntityHandle> quads;
+ // get local part handles and part ids
+ std::vector<iMeshP_PartHandle> local_handles;
+ std::vector<iMeshP_Part> local_ids;
+ ierr = get_local_parts( imesh, prtn, local_handles, &local_ids );
+ PCHECK;
+ // get loacal quads before exchange
+ quads.clear();
+ ierr = get_entities( imesh, local_handles[0], iBase_FACE, iMesh_QUADRILATERAL, quads );
+ CHKERR;
