[MOAB-dev] r5055 - MOAB/trunk/tools/dagmc
sjackson at cae.wisc.edu
Wed Jul 13 14:53:03 CDT 2011
Author: sjackson
Date: 2011-07-13 14:53:02 -0500 (Wed, 13 Jul 2011)
New Revision: 5055
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/DagMC.hpp
Log:
Allow the DagMC::get_angle function to accept an optional RayHistory,
and operate upon its most recent entry if one is available.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2011-07-12 21:43:23 UTC (rev 5054)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2011-07-13 19:53:02 UTC (rev 5055)
@@ -1111,15 +1111,24 @@
return MB_SUCCESS;
-ErrorCode DagMC::get_angle(EntityHandle surf, const double in_pt[3], double angle[3] )
+ErrorCode DagMC::get_angle(EntityHandle surf, const double in_pt[3], double angle[3], const RayHistory* history )
EntityHandle root = rootSets[surf - setOffset];
+ ErrorCode rval;
std::vector<EntityHandle> facets;
- ErrorCode rval = obbTree.closest_to_location( in_pt, root, numericalPrecision, facets );
- assert(MB_SUCCESS == rval);
- if (MB_SUCCESS != rval) return rval;
+ // if no history or history empty, use nearby facets
+ if( !history || (history->prev_facets.size() == 0) ){
+ rval = obbTree.closest_to_location( in_pt, root, numericalPrecision, facets );
+ assert(MB_SUCCESS == rval);
+ if (MB_SUCCESS != rval) return rval;
+ // otherwise use most recent facet in history
+ else{
+ facets.push_back( history->prev_facets.back() );
CartVect coords[3], normal(0.0);
const EntityHandle *conn;
int len;
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2011-07-12 21:43:23 UTC (rev 5054)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2011-07-13 19:53:02 UTC (rev 5055)
@@ -234,9 +234,12 @@
* @param surf Surface on which to get normal
* @param xyz Point on surf
* @param angle Set to coordinates of surface normal nearest xyz
+ * @param history Optional ray history from a previous call to ray_fire().
+ * If present and non-empty, return the normal
+ * of the most recently intersected facet, ignoring xyz.
- ErrorCode get_angle(EntityHandle surf, const double xyz[3], double angle[3] );
+ ErrorCode get_angle(EntityHandle surf, const double xyz[3], double angle[3],
+ const RayHistory* history = NULL );
