[MOAB-dev] r5050 - MOAB/trunk/test
iulian at mcs.anl.gov
Mon Jul 11 15:21:48 CDT 2011
Author: iulian
Date: 2011-07-11 15:21:47 -0500 (Mon, 11 Jul 2011)
New Revision: 5050
Added:
MOAB/trunk/test/mbground_test.cpp
Modified:
MOAB/trunk/test/Makefile.am
MOAB/trunk/test/mbfacet_test.cpp
Log:
do the "grounding line" split in a different test
it can be used separately to split an existing surface along a
polyline, with a preferred direction
Modified: MOAB/trunk/test/Makefile.am
--- MOAB/trunk/test/Makefile.am 2011-07-09 05:22:18 UTC (rev 5049)
+++ MOAB/trunk/test/Makefile.am 2011-07-11 20:21:47 UTC (rev 5050)
@@ -38,6 +38,7 @@
mbcn_test \
bsp_tree_poly_test \
mbfacet_test \
+ mbground_test \
gttool_test \
cropvol_test \
reorder_test
@@ -111,6 +112,7 @@
bsp_tree_poly_test_SOURCES = bsp_tree_poly_test.cpp
mbfacet_test_SOURCES = mbfacet_test.cpp
+mbground_test_SOURCES = mbground_test.cpp
gttool_test_SOURCES = gttool_test.cpp
cropvol_test_SOURCES = crop_vol_test.cpp
Modified: MOAB/trunk/test/mbfacet_test.cpp
--- MOAB/trunk/test/mbfacet_test.cpp 2011-07-09 05:22:18 UTC (rev 5049)
+++ MOAB/trunk/test/mbfacet_test.cpp 2011-07-11 20:21:47 UTC (rev 5050)
@@ -64,7 +64,6 @@
ErrorCode ray_test(FBEngine * pFacet);
ErrorCode split_test(Interface * mb, FBEngine * pFacet);
ErrorCode check_split(Interface * mb, FBEngine * pFacet);
-ErrorCode split_test_across();
ErrorCode split_quads_test();
@@ -165,11 +164,6 @@
if (only_cropping)
return number_tests_failed;
- // split_test_across
- std::cout << " split across test: ";
- rval = split_test_across();
- handle_error_code(rval, number_tests_failed, number_tests_successful);
- std::cout << "\n";
std::cout << " split quads test: ";
rval = split_quads_test();
@@ -592,113 +586,7 @@
return MB_SUCCESS;
-// this test will test a split like the one for grounding line
-// use the first and third point of the same polyline
