[MOAB-dev] r5045 - MOAB/trunk/test/parallel
kraftche at cae.wisc.edu
Thu Jul 7 12:11:03 CDT 2011
Author: kraftche
Date: 2011-07-07 12:11:03 -0500 (Thu, 07 Jul 2011)
New Revision: 5045
Modified:
MOAB/trunk/test/parallel/parallel_unit_tests.cpp
Log:
Fix parallel_unit_test bugs when run on more than two processes.
- All tests now pass on at least 8 processes except two-level ghosting
- Two level ghosting test fails on 5 or more processes. Before this
checkin it failed on any number other than 2.
Modified: MOAB/trunk/test/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/test/parallel/parallel_unit_tests.cpp 2011-07-06 22:03:15 UTC (rev 5044)
+++ MOAB/trunk/test/parallel/parallel_unit_tests.cpp 2011-07-07 17:11:03 UTC (rev 5045)
@@ -40,25 +40,12 @@
Utility Method Declarations
-// Get either all the entities in a set or only the entities of
-// a specific type, depending on whether or not type == MBMAXTYPE.
-ErrorCode get_set_contents( Interface& moab,
- EntityHandle set,
- EntityType type,
- Range& contents_out );
// Get processors an entity is shared with.
ErrorCode get_sharing_processors( Interface& moab,
EntityHandle entity,
std::vector<int>& other_procs_out );
-// Get mesh entities owned by a geometric entity set.
-ErrorCode get_geom_inclusive_mesh( Interface& moab,
- EntityHandle set,
- EntityType type,
// Create a parallel mesh
// Each processor will create four quads.
@@ -231,17 +218,6 @@
Utility Method Implementations
- EntityHandle set,
- EntityType type,
- if (type == MBMAXTYPE)
- return moab.get_entities_by_handle( set, contents_out );
- else
- return moab.get_entities_by_type( set, type, contents_out );
@@ -276,30 +252,7 @@
other_procs_out.push_back(procs[i]);
return MB_SUCCESS;
