[MOAB-dev] r4998 - in MOAB/trunk: src src/moab test
tautges at mcs.anl.gov
Tue Jun 14 10:19:01 CDT 2011
Author: tautges
Date: 2011-06-14 10:19:01 -0500 (Tue, 14 Jun 2011)
New Revision: 4998
Modified:
MOAB/trunk/src/ScdElementData.cpp
MOAB/trunk/src/ScdElementData.hpp
MOAB/trunk/src/ScdInterface.cpp
MOAB/trunk/src/SequenceManager.cpp
MOAB/trunk/src/SequenceManager.hpp
MOAB/trunk/src/StructuredElementSeq.cpp
MOAB/trunk/src/StructuredElementSeq.hpp
MOAB/trunk/src/moab/ScdInterface.hpp
MOAB/trunk/test/scdseq_test.cpp
Log:
Adding ability to represent periodic structured mesh, and corresponding
unit tests. Boxes can be periodic in i, j, or both; see ScdInterface.hpp
comments for details.
Modified: MOAB/trunk/src/ScdElementData.cpp
--- MOAB/trunk/src/ScdElementData.cpp 2011-06-14 14:21:02 UTC (rev 4997)
+++ MOAB/trunk/src/ScdElementData.cpp 2011-06-14 15:19:01 UTC (rev 4998)
@@ -24,14 +24,15 @@
namespace moab {
EntityID ScdElementData::calc_num_entities(EntityHandle start_handle,
- int irange, int jrange, int krange)
+ int irange, int jrange, int krange,
+ bool is_periodic_i, bool is_periodic_j)
size_t result = 1;
switch (CN::Dimension(TYPE_FROM_HANDLE(start_handle))) {
default: result = 0; assert( false );
case 3: result *= krange;
- case 2: result *= jrange;
- case 1: result *= irange;
+ case 2: result *= (is_periodic_j ? (jrange+1) : jrange);
+ case 1: result *= (is_periodic_i ? (irange+1) : irange);
return result;
@@ -39,15 +40,19 @@
ScdElementData::ScdElementData(
const int imin, const int jmin, const int kmin,
- const int imax, const int jmax, const int kmax)
+ const int imax, const int jmax, const int kmax,
: SequenceData(0, start_handle,
start_handle +
- calc_num_entities( start_handle, imax-imin, jmax-jmin, kmax-kmin )
+ calc_num_entities( start_handle, imax-imin, jmax-jmin, kmax-kmin, is_periodic_i, is_periodic_j)
- 1)
// need to have meaningful parameters
assert(imax >= imin && jmax >= jmin && kmax >= kmin);
+ isPeriodic[0] = is_periodic_i;
+ isPeriodic[1] = is_periodic_j;
elementParams[0] = HomCoord(imin, jmin, kmin);
elementParams[1] = HomCoord(imax, jmax, kmax);
elementParams[2] = HomCoord(1, 1, 1);
@@ -56,8 +61,8 @@
dIJK[0] = elementParams[1][0] - elementParams[0][0] + 1;
dIJK[1] = elementParams[1][1] - elementParams[0][1] + 1;
dIJK[2] = elementParams[1][2] - elementParams[0][2] + 1;
- dIJKm1[0] = dIJK[0] - 1;
