[MOAB-dev] r4996 - in MOAB/trunk: src/io src/parallel test/h5file test/parallel
kraftche at cae.wisc.edu
Mon Jun 13 18:41:10 CDT 2011
Author: kraftche
Date: 2011-06-13 18:41:09 -0500 (Mon, 13 Jun 2011)
New Revision: 4996
Modified:
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.hpp
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/test/h5file/h5sets_test.cpp
MOAB/trunk/test/parallel/parallel_hdf5_test.cc
Log:
o Reduce communication and computation negotiating type list during parallel
HDF5 write
o Fix bug: parallel HDF5 writer fails for polygons/polyhedra
o Fix bug: if a tag is not defined on the root process its default value
doesn't get written during parallel HDF5 write
o Fix bug: parallel HDF5 write fails if database contains no vertices
o Add unit test for parallel HDF5 write where some element types occur
only on processors other than the root
o Add unit test for parallel HDF5 write where some tags are defined
o Add unit test for parallel HDF5 write of polygons
o Add unit tests for writing list-type set containing stale entity handles
to HDF5 file
o Fix segfault in in HDF5 writer if debug output is enabled, moab is
compiled with parallel support, and a serial write is done (don't
dereference null ParallelComm pointer).
o Fix bug: HDF5 writer failed to write default value for handle tag
if it contained only zero-valued handles.
o Fix bug: parallel HDF5 writer fails if variable-length tags are defined.
o Fix bug: parallel HDF5 writer hangs writing variable-length tag data
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2011-06-13 23:40:42 UTC (rev 4995)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2011-06-13 23:41:09 UTC (rev 4996)
@@ -913,6 +913,9 @@
hid_t node_table;
long first_id, num_nodes;
+ if (!nodeSet.total_num_ents)
+ return MB_SUCCESS; // no nodes!
CHECK_OPEN_HANDLES;
rval = iFace->get_dimension( mesh_dim );
@@ -2037,10 +2040,9 @@
size_t remaining = range.size();
size_t offset = tag_data.sparse_offset;
size_t num_writes = (remaining + chunk_size - 1)/chunk_size;
- //size_t num_global_writes = num_writes;
if (tag_data.max_num_ents) {
assert(tag_data.max_num_ents >= (unsigned long)remaining);
- //num_global_writes = (tag_data.max_num_ents + chunk_size - 1)/chunk_size;
+ num_writes = (tag_data.max_num_ents + chunk_size - 1)/chunk_size;
Range::const_iterator iter = range.begin();
while (remaining)
@@ -3119,10 +3121,8 @@
// convert default value
if (def_value) {
memcpy( dataBuffer, def_value, def_val_len*sizeof(EntityHandle) );
- if (convert_handle_tag( reinterpret_cast<EntityHandle*>(dataBuffer), def_val_len ))
- def_value = dataBuffer;
- else
- def_value = 0;
+ convert_handle_tag( reinterpret_cast<EntityHandle*>(dataBuffer), def_val_len );
+ def_value = dataBuffer;
// convert mesh value
Modified: MOAB/trunk/src/io/WriteHDF5.hpp
--- MOAB/trunk/src/io/WriteHDF5.hpp 2011-06-13 23:40:42 UTC (rev 4995)
+++ MOAB/trunk/src/io/WriteHDF5.hpp 2011-06-13 23:41:09 UTC (rev 4996)
@@ -95,12 +95,19 @@
//! processor.
long total_num_ents;
- bool operator<( const ExportSet& other ) const
+ bool operator<( const ExportType& other ) const
{ return type < other.type ||
