[MOAB-dev] [Itaps-users] [PATCH 1/2] iMesh_MOAB: do not allocate new memory for count=0 items
Tim Tautges tautges at mcs.anl.gov
Fri Jun 10 13:22:02 CDT 2011
On 06/10/2011 01:03 PM, Jed Brown wrote:
> On Fri, Jun 10, 2011 at 19:43, Tim Tautges <tautges at mcs.anl.gov
> <mailto:tautges at mcs.anl.gov>> wrote:
>     I'm fine with at least not allocating for count = 0, and my read of
>     the iMesh spec is that it's silent on this issue.
> It's subtle. The letter of the spec suggests (to me) that if you pass in
> UNALLOCATED (currently defined using OR), you get a pointer that free()
> can be called on. This pointer may or may not be NULL (some malloc()
> implementations return NULL on zero-length allocation, others return a
> pointer that can be freed). I doubt this was intentional; the zero
> length case was probably not considered explicitly.
Ok, I didn't think of that.  I think we should clarify the wording in the spec on that.
> If nobody has a dependency on allocation of zero length returns, I think
> the wording should just be clarified.
>       I think we (Jason & I) were for the OR instead of AND (i.e.
>     allocating if either the allocated_length is 0 or the array ptr is
>     NULL) just to avoid the nuisance of having to initialize more stuff.
>       That's not a strong preference though.
> I don't have a strong preference here, but memory allocation and
> ownership is something that C programmers need to pay attention to. An
> extra "=0" is not a great burden, especially if it improves semantic
> clarity.
I'd prefer to leave it as-is, though again not strongly.  I'll put the question to itaps anyway, though.  I'll also
change the implementation along the lines of your patch.
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
