[MOAB-dev] [Itaps-users] [PATCH 1/2] iMesh_MOAB: do not allocate new memory for count=0 items
Tim Tautges
tautges at mcs.anl.gov
Fri Jun 10 12:43:13 CDT 2011
I'm fine with at least not allocating for count = 0, and my read of the iMesh spec is that it's silent on this issue. I
think we (Jason & I) were for the OR instead of AND (i.e. allocating if either the allocated_length is 0 or the array
ptr is NULL) just to avoid the nuisance of having to initialize more stuff. That's not a strong preference though.
- tim
On 06/10/2011 07:23 AM, Jed Brown wrote:
> Upon re-reading the iMesh.h spec, this would be a change of
> If a list argument is unallocated (the list pointer points to a NULL
> value) or if the incoming value of the allocated size is zero, the list
> storage will be allocated by the implementation. IN ALL CASES, MEMORY
> ALLOCATED BY ITAPS INTERFACE IMPLEMENTATIONS IS DONE USING THE C MALLOC
> FUNCTION, AND CAN BE DE-ALLOCATED USING THE C FREE FUNCTION.
> to only allocating memory if the result size is also positive. I think
> my semantics are much more practical. The only place where it is
> backward incompatible is when the caller passes in
> list = undefined;
> alloc = 0;
> iMesh_callReturningList(...,&list,&alloc,&size,...);
> for (i=0; i<size; i++) use(list[i]);
> free(list);
> This can be fixed by simply setting list = NULL before the call. Doing
> so is no burden and if anything, makes the code clearer. In the interest
> of clarity, I don't think it would be unreasonable to require that BOTH
> list=NULL and alloc=0 for library-allocated memory. It becomes an
> iBase_BAD_ARRAY_SIZE if list=non-NULL, alloc=0, and a positive number of
> items are to be returned.
> In any reasonable scenario I can envision, the caller knows statically
> whether they want the library to allocate memory or not. The caller
> would need a run-time check to determine whether they computed an
> expected array length that was positive or equal to zero.
> For my use case (filling a preallocated contiguous buffer in segments)
> the user would need to have an if statement and avoid the call when an
> empty array is expected. This makes user code ugly and fragile.
> On Fri, Jun 10, 2011 at 14:08, Jed Brown <jed at 59a2.org
> <mailto:jed at 59a2.org>> wrote:
> It is relatively common to fill a buffer with consecutive queries, some
> of which may return zero items. In such scenarios, the user passes in a
> valid pointer, but occasionally a length of 0. In such scenarios,
> having the library allocate a new buffer of zero length is not
> desirable.
> On the other hand, if a user knowingly passes in a length of zero, but
> undefined pointer value, they would expect the library to return a
> pointer that can safely be passed to free(). A workaround is to nullify
> the pointer prior to calling iMesh with expectation of a new array.
> itaps/imesh/iMesh_MOAB.hpp | 2 +-
> 1 files changed, 1 insertions(+), 1 deletions(-)
> Itaps-users mailing list
> Itaps-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/itaps-users
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
